Old 12-23-2023, 02:45 PM   #26
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Steering Mystery - I Need Help!
Originally Posted by dmjlambert View Post
Just wondering here, are 4WD susceptible to the same infamous steering center link installed backwards that 2WD C-10's get?
I'm glad you asked... I have been following this thread with the same question in mind. I bet we find out before long.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-23-2023, 03:36 PM   #27
Rust_never_sleeps
Rust_never_sleeps's Avatar
Wouldn't it be impossible to set the toe-in to 3/16" or anything close with the center link reversed?
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 12-23-2023, 03:57 PM   #28
Richard
Here is an older thread on K series caster. https://67-72chevytrucks.com/vboard/...ght=k10+caster
Post #13 shows factory caster settings for the different years.
Richard
Old 12-23-2023, 05:37 PM   #29
dmjlambert
dmjlambert's Avatar
I don't know, but I think there is a great range of adjustment in the tie rods, and there have been some threads in the forum about 2WD C-10's having wacky steering with the center link backwards being the culprit, so had to ask for those familiar with 4WD.
Old 12-23-2023, 06:18 PM   #30
A1971Blazer
A1971Blazer's Avatar
the 4x4 has front to back steering at the driver side steering knuckle….it has a tie rod across to the passenger side knuckle…completely different from 2wd steering
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 12-24-2023, 02:12 AM   #31
Richard
As A1971Blazer stated the steering is real simple. On driver side an adjustable draglink from pitman arm on steering box to steering arm on driver knuckle and a single tierod that connects the left and right knuckles together. Do no think there is anyway to install the pieces wrong. If a steering stabilizer mount is on the tie rod it most likely will need to be adjusted.
Richard
Old 12-26-2023, 08:49 PM   #32
truckster
truckster's Avatar
Follow up: I checked everything out today. All of the joints (ball joints, tie rod ends, etc.) are really nice and tight. The rag joint is good. I put in the caster shims (thick end toward the back) and it tracks nice and straight, but the steering is still loose. I adjusted the steering box 1/8 turn and it helped a bit, but it was an O'Reilly's reman box when I installed it, and I suspect I just need to replace it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 12-26-2023, 09:12 PM   #33
dmjlambert
dmjlambert's Avatar
I suggest adjust the thrust bearing preload followed by the over-center preload. Thrust bearing preload amounts to tighten the big threaded plug all the way and back it off by 1/2 inch thread movement. Then make sure you can feel it takes additional torque to turn the input shaft when you go over center. Measure where over center is by counting the turns from one end of steering to the other. Adjust the over-center preload screw if necessary. Here is the official procedure with some minor amounts of thoughts added.
http://67-72chevytrucks.com/vboard/s...d.php?t=812162
Old 12-26-2023, 09:19 PM   #34
truckster
truckster's Avatar
Thanks for the write-up. I'll give that a try tomorrow. I haven't built a tool in the past couple of days so it's about time.
1995 Camaro Z/28
Old 12-27-2023, 06:49 PM   #35
truckster
truckster's Avatar
Well, I adjusted the gearbox but it's still really sloppy. I think it's the cheap rebuild quality - I've been told they clean them, replace the seals, paint them, and box them up.
I just ordered from Redhead. Just over $500 with shipping, not including the core charge. I hope it's worth it.
1995 Camaro Z/28
Old 01-08-2024, 10:41 PM   #36
truckster
truckster's Avatar
Here's my follow-up:
As mentioned, I replaced the ball joints, tie rod ends, all the bearings, seals, etc.
I reinstalled the caster shims, this time with the wide end to the rear. It was tracking straight, but the steering was really loose. I bought the Redhead steering gear and a new coupler (rag joint). Now it tracks straight and true and the steering is nice and tight.
Thanks for all the advice.
1995 Camaro Z/28
