Old 01-09-2024, 01:04 PM   #1
Baketown Scotty
Junior Member
Baketown Scotty's Avatar
Need help dismantling spring hanger
1966 GMC Suburban 4WD
I'm having trouble removing the pin/ bolt from a frame bracket that connects the front leaf spring rear hanger to the frame. It looks to be threaded but can only get it to turn just a bit. I've used PB Blaster but have not tried heating it yet. Is it threaded or does it need to be pressed out? C catalog does not appear to show it being threaded. I would like to remove it before sandblasting the frame. Here are a couple of pictures.
1964 Chevy Suburban 4x4
1966 GMC Suburban 4x4
Baketown Scotty is offline   Reply With Quote
Old 02-23-2024, 06:57 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Need help dismantling spring hanger
you need a good torch and heat the pi$$ out of the bracket and it should come out. if you're replacing the stud heat it up and smack it with a BFH.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 02-24-2024, 12:11 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
+1 they can be a real pita, especially as these old beasts continue to age.
Tyler
Old 03-05-2024, 12:47 AM   #4
Baketown Scotty
Junior Member
Thanks for the input. More PB Blaster, some heat and was able to unscrew them. Fine threads on outer ends with coarse threads in the middle.
Old 03-07-2024, 05:49 PM   #5
dennislbrooks
dennislbrooks's Avatar
I replaced the bushings also on my 59. I used a ball joint installer remover to push it all out. Your bushings are probably wore also.
I push later model rubber bushings out same way. No burning them out.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
