Old 01-15-2024, 07:46 PM   #1
novaX522
Front sway bar install
Today I installed the front sway bar. It is FSBK6372 from POL. I bought the front and rear in a kit. Nice looking bar, I can see it making a difference.
novaX522 is offline   Reply With Quote
Old 01-16-2024, 11:53 AM   #2
ghackett1
68 C10 Longbed
ghackett1's Avatar
Re: Front sway bar install
https://www.67-72chevytrucks.com/vbo...1&d=1705420348
Looks great, I went with the CCP brackets and an original front bar.
ghackett1 is offline   Reply With Quote
Old 01-16-2024, 02:19 PM   #3
MS66
MS66's Avatar
Same here. Factory 1 1/8" bars really help these trucks out. Not sure I need a rear bar now.
MS66 is offline   Reply With Quote
Old 01-17-2024, 02:43 PM   #4
adf5565
What is the purpose of using the sway bar frame stand off bracket vs just attaching the mount to the frame?
adf5565 is offline   Reply With Quote
Old 01-17-2024, 03:11 PM   #5
novaX522
I don’t know for sure, but this bar from POL was designed to mount on frame. I’m guessing the bar is contoured so it can be mounted like that. Maybe the bars that use the mounting bracket are straighter. I noticed some sway bar kits have short and tall mounts in case your truck has been lowered.
Old 01-17-2024, 05:19 PM   #6
ghackett1
68 C10 Longbed
ghackett1's Avatar
Not sure, but that’s how the General did it originally. I used an original sway bar and my truck sits at factory height so I didn’t feel like reinventing the wheel.
Old 01-18-2024, 10:46 AM   #7
1967GMCC20
1967GMCC20's Avatar
Nice looking, need one for my 67 3/4 2wd.
1967GMCC20 is offline   Reply With Quote
Old 01-18-2024, 12:24 PM   #8
72SB
IMHO adding a 1 1/8 front sway bar vs none make a big improvement in handling (body roll). My 72 did not come with one so I installed the one I got from LMC
72SB is offline   Reply With Quote
Old 01-18-2024, 12:48 PM   #9
1967GMCC20
1967GMCC20's Avatar
Go Canada....
The first stabilizer bar patent was awarded to Canadian inventor Stephen Coleman of Fredericton, New Brunswick on April 22, 1919.[1][2]
Old 01-18-2024, 01:32 PM   #10
kwmech
Drove my 68 C20 for years without a bar, then one came up on a truck my son-in-law was parting out. I installed it--all factory parts--made a huge difference driving the mountain roads I live in. Night and day difference
Old 01-18-2024, 07:16 PM   #11
custom10nut
custom10nut's Avatar
It’ll be the difference between night and day.
I put mine on many years ago, and was immediately satisfied with the way it firmed up everything.
I got mine from an old salvage yard frame in NC.
I got it for a steal but had to put in the “Sweat Equity” by removing the perches by hand. (I used a little saws all, a chisel, a 4lbs sledge, and a pry bar, to cut the factory rivets)
Mid-July heat in Fayetteville NC is no joke.
custom10nut is offline   Reply With Quote
Old 01-18-2024, 10:47 PM   #12
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Years ago I put a front bar on and couldn’t believe the difference. Now years later I have Full QA1 Suspension front and rear. Rides Great, Handles like a Go Cart. Love it
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 01-18-2024, 11:29 PM   #13
novaX522
That’s a nice setup!
Old 01-19-2024, 01:14 AM   #14
MS66
MS66's Avatar
Same thing I did, scratched it all off of a 2500, frame brackets and all. I've done several trucks like this, world of difference. Especially when you use Energy Suspension bushings.
Old 01-19-2024, 06:47 AM   #15
ghackett1
68 C10 Longbed
ghackett1's Avatar
Very nice!
Old 01-19-2024, 08:32 AM   #16
A1971Blazer
A1971Blazer's Avatar
My '67 build has QA1 front and rear, It's not quite ready to go on the road but I'm getting close(and super anxious!).
I went with 2" drop spindles and 650# springs on the front with dual adjustable shocks.
What settings are you running on the shock adjustments?
I know it may take some "dialing in" .....just looking for a starting point for the best all around ride/handling settings.
I'm running an all aluminum LS1 so it's about 100# lighter in the front than a standard small block.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 01-19-2024, 08:40 AM   #17
yuccales
yuccales's Avatar
Got to agree. Of all the tinkering I've done, the front sway bar and headlight relays have made the most difference to me.
yuccales is offline   Reply With Quote
Old 01-19-2024, 09:37 AM   #18
ghackett1
68 C10 Longbed
ghackett1's Avatar
Ditto:
I also added a rear sway bar, the difference with both is unbelievable. The truck maneuvers much better.
Old 01-19-2024, 12:33 PM   #19
1970 CST Short Wide
Senior Moment
I too have an all aluminum 5.7 LS1. My shocks are single adjustable 2” spindles
And #750 springs (recommended by QA). Im at 6 in the front and 4 in the rear
Nice thing is if you don’t like it you have 18 adjustment points that can be made in a matter of minutes
Pittsburg Ca
94565
Old 03-08-2024, 09:18 PM   #20
Hupper7
I just bought the front and rear POL sway bars for my C20 with coils.
These pictures help. The directions included from POL aren't that helpful.
Was trying to figure out how the 'L' bracket was going on to the front Arm.
Do you have any pics of the rear installed?
Hupper7 is offline   Reply With Quote
Old 03-08-2024, 11:37 PM   #21
novaX522
[QUOTE=Hupper7;9294270]I just bought the front and rear POL sway bars for my C20 with coils.
I have another post called rear sway bar install. I tried to copy and paste the link here:
http://67-72chevytrucks.com/vboard/s...d.php?t=849910
Old 03-09-2024, 12:47 AM   #22
Hatzman
Hatzman's Avatar
You put a 70's C10 on a 2500 chassis? Any pics?
Steve
___________________________________
http://67-72chevytrucks.com/vboard/s...d.php?t=618848
Hatzman is offline   Reply With Quote
Old 03-09-2024, 01:39 PM   #23
novaX522
I wasn’t able to get the correct link. I took some pictures of the rear sway bar. Let me know if you need different pictures.
Old 03-09-2024, 01:48 PM   #24
Hupper7
Sir, that is a huge help.
Thanks for posting this.
And I appreciate how clean your under carriage is !
Old 03-09-2024, 01:52 PM   #25
Hupper7
And one other question. The bolts going on the trailer arm, are they positioned on each side of the ‘C’ shaped bar?
When I picked them up at POL, the salesman told me that would be the position.
Just checking in with someone who has installed them.
