Old 01-20-2024, 09:54 AM   #1
44SAA
High Beam/Trans Neutral?
Gentlemen- I have spent a week examining my ‘80 C20 350/350 wiring manual with no avail. In short, can anyone assist in identifying this LT GRN wire. Best I can tell it is for either BU lights, Hi beams or trans neutral switch. However, my BU lights are working. The wire originates from a grommet in the firewall behind the instrument panel. It seems unusually long. I am severely colorblind and this has been a challenge…
Thank You, Single Action Army
44SAA is offline   Reply With Quote
Old 01-20-2024, 11:24 AM   #2
Getter-Done
Getter-Done's Avatar
Re: High Beam/Trans Neutral?
Does your parking brake have a switch on it?
It could be the parking brake indicator light.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 01-20-2024, 11:34 AM   #3
44SAA
Thank you Getter. It does, but wiring schematic shows BLK/LT BLU and GRAY to Park SW.
Old 01-20-2024, 12:13 PM   #4
kwmech
Looks like an added wire long ago from a previous owner
Old 01-20-2024, 12:32 PM   #5
Dead Parrot
Green is often used for:
Temp Gauge/Idiot sender
AC clutch
Possible a PO ran a new wire while trying to figure out why the temp gauge never moved. Often happened if the OEM sender was replaced.
Dead Parrot is offline   Reply With Quote
Old 01-21-2024, 05:05 PM   #6
temp190
Junior Member
Best thing to do is start tracing it back, where does it go, what does it connect to at other end.
temp190 is offline   Reply With Quote
Old 01-21-2024, 06:51 PM   #7
44SAA
Curiosity led to me yanking out the instrument panel. The wire wasn’t factory and probably used for POs CB hookup. Oh well, now I can take a shot at replacing the speedo needle and burned out indicator lamps. Thank you for everyone’s help.
