Junior Member
![]() Join Date: Jul 2023
Reusable garage paint booth help
I would appreciate any help you pros/diyers" can give me on a garage paint booth setup
Questions: What mil should I get and where to find it Can I setup on a roll type system for up/down. How much room needed around a fully assembled k20. I do expect to break it down to cab. Doors fenders hood Bed and engine/trans and transfer case. Reasons for assembled work area. Lastly I like Eastwood shop vac for my sanding. Anyone else have good results using that. ? Mike |
Re: Reusable garage paint booth help
Are you spraying a solid color or metallic? Solid color you could spray assembled but per my body shop friend its so much easier to get good coverage spraying panels apart.
Metallics should be sprayed assembled. Lot's of back taping. |
Junior Member
I'm restoring it back to 1 color red red that my dad and I drove it off the dealers lot in 72.I do want to do the parts like the hood doors cowl etc piece meal.. my 1st paint job
![]() Join Date: Apr 2016
Check this out at Fitzee’s Fabrications:
https://youtube.com/playlist?list=RD...QdYdxOAh-gR4o2
1972 GMC K2500 Super Custom Matt |
![]() Join Date: Dec 1999
I used a pop up shelter for my roof/structure. I go a 10x20 shelter, that included fabric walls. The problem I found was, the fabric walls move too much. I suspect plastic might do the same?
I made walls from 4x8 sheets of single ply cardboard, which a box place near me sells for around $5 per sheet. I made a frame from 1x2 firring strips that I got from Home Depot that are up to $1.58 each. By, made a frame, basically what I did was lay out the cardboard to the size and shape I wanted and then slid the wood under the edges and stapled the cardboard to the wood. Combined, they made a pretty decent structure. The end walled ended up 10ft wide x 8ft high. I ran some firring strips vertical between the sheets like studs There were areas that I needed something longer than 8ft, so I overlapped firring strips and used 1 inch finishing nails to splice them together. When I was done, I threw al the cardboard and firring strips away. I'll see if I can come up with some pictures. |
Here's one...
You asked about size. My 10x20 would not have been big enough for a fully assembled vehicle. 12ft width minimum. I did the bed fully assembled, but was able to roll it side to side as I was doing it. Thankfully I had help.
#8 | |
On my build thread towards the end you will see the one I built https://67-72chevytrucks.com/vboard/...&postcount=150
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
![]() Join Date: Sep 2002
While I don't have any direct experience with the blow up types, here are my observations:
After several paint jobs, what do you do about the eventual accumulation of overspray on the clear plastic? If you want it to stay transparent, I suppose you could cover them with removable plastic. Same with the floor. I've seen some cover the floor with plastic. Contingency plans in the event of a power failure. The roof needs to be supported in case the fans die and it falls on the vehicle. A friend used one and he wasn't impressed with the evacuation rate of the paint mist, especially the clear coat. I've seen options to add an additional fan. That might help. I couldn't find a size big enough to fit an average sized vehicle and yet be small enough to fit in my bay. For a quick setup and teardown assembly these extra steps and limitations just don't make it worth it to me. I have a temporary booth made of 1 1/4" PVC and 1 1/2" chain link fence tubing for the frame and plastic sheeting. It was a bit involved to design the structure around the garage door tracks but it only takes a full weekend to setup. (It took a few weeks for the initial construction and setup). I use a typical sized bank of intake and exhaust filters and a 5HP, 3' diameter fan with a large plenum. Works beautifully.
1966 C10 Custom Cab Restomod (Sold) 1969 Camaro Z/28 (Keeper) Current Build: 1968 C10 (Semi-Factory Restoration) 1983 Camaro Z/28 (Next in line, Keeper) 1951 3100 (2nd in line) |
Maybe not for you but a local body shop painted parts for me one or two at a time. All were base coat clear coat solid colors. Materials are expensive so doing stuff twice gets expensive.
I would strip the body panels and take them to the body shop and they would epoxy prime them to keep flash rust away. Them I would store them away until body work time. When all that was complete I again then body worked/block sanded each part as needed. Parts went back to the body shop for paint, wet sanding and buffing. |
#11 | |
You are very right about the floor. Look at the floor in the picture I posted. I was using Southern Polyurethanes epoxy and it's very sticky. I had paper/chipboard on the floor originally and you can see where it is all ripped up from sticking to my feet. After that experience I went and got cheap roll vinyl flooring and it worked much better. |
1 have a 12x21 metal carport on a concrete slab. I put 4 mil clear plastic. (10') and lay 2x4s on the roof edge. On the downwind side, usually north, I have two box fans blowing out and on the upwind side 2- 20"x30" hvac filters for incoming air. I spray the floor down and go at it. I'm going to fix it up again for painting my camaro. It takes about 2 hours to prep for work. Carport is in the background.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5 |
![]() Join Date: Feb 2016
You might take a stroll through these threads for information and inspiration.
http://www.spiuserforum.com/index.ph...aint-booth.15/
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
