02-01-2024, 11:22 PM | #1 |
Kung Fu Master
VIN plate restoration
I should have protected this better before the blaster had a go at it. Can these be brought back to original condition?
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 Last edited by WestButteTruck; 02-01-2024 at 11:25 PM. Reason: Spelling |
02-01-2024, 11:45 PM | #2 |
Re: VIN plate restoration
I wonder what is the deal with the wavy metal and the wads of what appears to be chewing gum under it, how did that happen? I don't know what I would do, probably polish it with some Colgate toothpaste and soft rag and see what you get. And at least cut off straight the wads of gum using a putty knife. If it is going to be a show truck, that will detract from it a little, but nobody will be accusing you of altering the VIN plate from original so it should be OK in that condition for titling the truck, just my opinion.
02-02-2024, 12:18 AM | #3 |
Kung Fu Master
I think the material from the blaster must have distorted it some. As for the white material underneath, I haven't looked at it too closely but was thinking it was seam sealer.
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 |
02-02-2024, 12:31 PM | #4 |
It's readable and the rivets are correct, it's a 50 year old truck I'd leave it as is...Just make sure to protect it from the painter/body man now.
02-03-2024, 10:41 AM | #5 |
02-03-2024, 12:07 PM | #6 |
So.. this IS available. Can't vouch for its quality nor endorsing..
https://www.ebay.com/itm/254631328996
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
02-04-2024, 11:32 AM | #7 |
Yes, those are available, and they are most likely illegally sold. I would recommend not purchasing one as it may lead you down a road you will likely regret.
02-04-2024, 01:07 PM | #8 | |
Altering Or Removing Motor Vehicle Identification Numbers Section 511 (a) of Title 18 makes it a felony knowingly to remove, obliterate, tamper with, or alter an identification number for a road motor vehicle or a road motor vehicle part. |
02-04-2024, 02:21 PM | #9 |
Remember the word INTENT
So.. any restorer that has replaced a MoPar E body dash pad is a felon? Depends if the LEO is a real tool or not. In this hobby, sometimes the VIN tag must be disturbed to properly repair the vehicle. If your intent is to defraud or commit other crimes, then by all means, the book should be thrown at you...
02-04-2024, 08:18 PM | #10 |
Kung Fu Master
Yeah, I intend to keep what is on there. I will try a couple things to see if I can improve the looks some. I looked into that ebay tag, shipped from overseas but it does look nice. Really just bummed with my lack of doing something to protect it in the first place.
02-04-2024, 09:38 PM | #11 | |
All about them Ks
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5 lift, 35s, front dana 60 blah blah blah http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB: 4 lift 33s in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20s |
02-05-2024, 10:38 AM | #12 | |
02-05-2024, 11:29 AM | #13 |
Moderator
The eBay vin plate is sold out of the Netherlands, probably to avoid any legal action.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-05-2024, 11:38 AM | #14 | |
02-05-2024, 12:59 PM | #15 |
I have a question. This may be tampering as well but I was wondering if you could polish the plate up on the truck best you can and Mabey just get a vinyl decal made with the wording and just apply it to the original vin plate on the truck to make it look cleaner? I assume this is not legal but just inquiring.
02-05-2024, 01:10 PM | #16 |
BlahBlahBlah
I have a friend that bought a new vin tag for his 67 from I believe the same place. His original was damaged. It looks spot on to me.
I dont know if the place required a look of his old one or if he just told them the numbers. Im surprised the blasting company didnt tape the OP's over good before they blasted. Ive had a couple vehicles blasted now and they taped over them well enough so they werent damaged.
02-05-2024, 01:32 PM | #17 |
So, being up-front, I was in law enforcement for a while. There are exemptions to Federal law that would allow one to remove their VIN plate. The kicker is checking your state law to see if they are OK with doing what you want to do. If you retain the original in the glove box to show the new one is a direct copy of the old one you may be OK, BUT...check with your state.
Here is an excerpt of the Federal law: Section 511(a) of Title 18 makes it a felony knowingly to remove, obliterate, tamper with, or alter an identification number for a road motor vehicle or a road motor vehicle part. Section 511(b) of Title 18 creates exceptions for certain persons who engage in lawful conduct that may result in removal or alteration of an identification number. The legislative history is abundantly clear that subsection (b) is not intended to create a loophole for the operators of "chop shops." See H.R.Rep. No. 1087 on H.R. 6257, 98th Congress, 2d Sess. 23-25 (1984). Exemptions to VIN tampering in Federal Law: (2) The persons referred to in paragraph (1) of this subsection are-- (A) a motor vehicle scrap processor or a motor vehicle demolisher who complies with applicable State law with respect to such vehicle or part; (B) a person who repairs such vehicle or part, if the removal, obliteration, tampering, or alteration is reasonably necessary for the repair; (C) a person who restores or replaces an identification number for such vehicle or part in accordance with applicable State law; and (D) a person who removes, obliterates, tampers with, or alters a decal or device affixed to a motor vehicle pursuant to the Motor Vehicle Theft Prevention Act, if that person is the owner of the motor vehicle, or is authorized to remove, obliterate, tamper with or alter the decal or device by-- (i) the owner or his authorized agent; (ii) applicable State or local law; or (iii) regulations promulgated by the Attorney General to implement the Motor Vehicle Theft Prevention Act. ...The lawful removals can be found in 18 U.S.C. §§ 511(b) and 512(a)(3). Under subsection 511(b), these lawful exceptions do not apply if the person knows that the motor vehicle or part is stolen. Except for the area of "repair," these exceptions should cause no significant enforcement problem. The relevant portion of H.R.Rep. No. 1089 on H.R. 6257, 98th Cong., 2d Sess. 23-25 (1984), makes clear that the "repair" exception is intended for the protection of the honest body shop operator who while fixing a part does some injury to its identification number. The exception "is not intended to apply to the operators of "chop shops,' who remove such parts - not repairing or recycling them for lawful purposes." Most of the states that are parties to the interstate compact, which created the Vehicle Equipment Safety Commission (VESC), have established under their respective state laws, procedures for the restoration and replacement of missing identification numbers. See Regulation VESC-18, Standardized Replacement Vehicle Identification Number System. Bottom line, check with your state. Let them know you are the owner and are conducting a restoration of your vehicle. |
02-05-2024, 08:31 PM | #18 |
Kung Fu Master
Good idea with checking with local and state laws first. I don't plan to remove it, but I do plan to check and see what the law is here in MT just out of curiosity now. Thanks for all the replies. As you can see, I have a lot of work to do on this thing. lol
02-05-2024, 08:47 PM | #19 |
We used to remove vin plates regularly in the 70s and 80s at my uncles shop . There is a process of going through DMV who sends a state trooper to verify the vin that’s being removed . And again at the time it’s reattached to the door post . As long as all the info is correct the trooper signs off on it . We were even able to get the correct rivets . Paperwork must remain with the vehicle ( not physically) and given to any subsequent owner . Some states have their own laws that may be much more stringent than the federal law
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
