Old 02-04-2024, 06:44 PM   #1
62 Barnfind
62 Barnfind's Avatar
60-62 bell housing color
Does anyone know what the correct color of the manual bell housings were on the 60-62?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 02-04-2024, 07:38 PM   #2
bhap
bhap's Avatar
Re: 60-62 bell housing color
My bellhousing was medium gray - same as the 235…
bhap is offline   Reply With Quote
Old 02-04-2024, 09:13 PM   #3
62 Barnfind
Thanks!
John Z
62 Barnfind
Old 02-05-2024, 08:11 AM   #4
RustyPile
RustyPile's Avatar
Depends on the engine, 235s were medium gray.. V-8s were Chevrolet Orange... "Big" sixes, I'm not sure....
RustyPile is offline   Reply With Quote
Old 02-05-2024, 10:52 AM   #5
sirJim
My 62 suburban 235 was a green.
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 02-05-2024, 06:26 PM   #6
dmb
Active Member
dmb's Avatar
Dang the clutch fork is on the wrong side, Is it a right hand drive?
dmb is offline   Reply With Quote
Old 02-05-2024, 09:43 PM   #7
62 Barnfind
I wanted to check to see if they were painted the engine color or just cast. My 235 had gray on it but most of it was worn off. So I couldn’t tell for sure. Im building a 350 to replace the 235 and it will be Chevy Gray like the 283s had in these trucks. So now I’ll paint it to match. Thanks for the help!
John Z
62 Barnfind
Old 02-06-2024, 12:38 AM   #8
cwcarpenter98
cwcarpenter98's Avatar
For the US 60-66 trucks, 283s were gray, the 327 in 66 was very close to Detroit Diesel Green (forget exact name at the moment). Chevy Orange didn't hit the US trucks until 67
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-06-2024, 10:31 AM   #9
rbruno68
John Z, my plan is the same. I would like to paint my 350 the grey that would have been on the 283. I have read other threads here, but not sure about sourcing the paint. Have you got your paint and painted the motor yet?
rbruno68 is offline   Reply With Quote
Old 02-06-2024, 10:52 AM   #10
60-66
60-66's Avatar
No orange engines in any 60-66 Chevrolet trucks from the factory . 283 was gray and 327s green in 10-30 series
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 02-06-2024, 10:54 AM   #11
60-66
60-66's Avatar
Do you still have the 6 cylinder that was part of this Bell Housing ? Reason I ask is , the 261 Six that was optional 60-62 was green , 235s were gray
Old 02-06-2024, 11:40 AM   #12
sirJim
No I dont have it just always thought it was a 235. Never tore it apart to find out. Might have been a 261
Old 02-06-2024, 10:10 PM   #13
62 Barnfind
Yes. I got it from KBS coatings. I brushed the block and sprayed the oil pan and valve covers. Since these trucks had gray and green engines I wanted to stay with one of the colors.
John Z
62 Barnfind
Old 02-06-2024, 10:11 PM   #14
62 Barnfind
I bet you have a 261. My 235 was gray.
John Z
62 Barnfind
Old 02-07-2024, 10:16 AM   #15
rbruno68
Thanks. I just looked at their products. I think I will definitely go with their kit. My motor has a little surface rust on the pan and their etch seems like it would do the trick.
Old 02-17-2024, 01:41 PM   #16
62 Barnfind
Bell housing in paint. Now I’m trying to find the correct flywheel dust cover for it. Not much information on it.
John Z
62 Barnfind
Old 02-17-2024, 06:48 PM   #17
ray_mcavoy
Looks great! I believe these bell housings used a 2-piece cover like this:
https://www.classicparts.com/1955-72...info/90%2D915/
https://www.classicparts.com/55-72-B...info/90%2D914/
ray_mcavoy is offline   Reply With Quote
Old 02-18-2024, 06:28 PM   #18
62 Barnfind
Thanks! I think that’s it.
John Z
62 Barnfind
