02-25-2024, 05:21 AM | #26 | |
Re: Fuel line question
02-25-2024, 12:35 PM | #27 |
Scroll down to page 410/726 That is the start of the exhaust section. https://www.trifive.com/d1/55-59Assy.pdf
Save the link to your favorites as it answers a lot of questions one has and it is one of the resources we answer questions with.
02-25-2024, 01:54 PM | #28 |
yeah, thats the same page I entioned earlier. lots of great info in the manual. yes, sometimes not the greatest definition on the lettering etc, like a printed copy would have, but if you are just trying to figure out how it looks and aren't doing a numbers matching build then it's all you need.
think of it how it is, you are hanging an exhaust system. it needs to bolt up to the manifold at one end and then be supported along it's length till it exits. it needs some flexibility a little way back from the manifold connection so there is some allowance for the engine moving under torque, it is usually good to support the pipe somewhere around the muffler as this is the heaviest part of the system, and it is good to keep a distance from any frame or body parts along the way so nothing rubs under movement from engine torque or general frame/body flexing over different terrain etc. if you were to look at a modern vehicle the system hangs on the manifold and then nottoo far away is usually a flex joint/pipe to allow a lot of flex from the engine torque, then a little back from there is a very flexible hanger system, usually rubber of some sort, that hangs the pipes and mufflers etc. |
02-25-2024, 02:06 PM | #29 |
personally, on a vehicle that has not got the more modern rubber hanger mounts, I like to use this style of hanger which simply uses a cheap clamp to attach to the pipe. on the frame end of things i usually use a short length of flat bar as a washer to keep the fastener from working through the rubber. the rubber on these is like a tire or conveyor belt material with lots of fiber strands to keep it flexible but not easily stretched out and broken.
https://www.summitracing.com/parts/aph-8462 this style is another of my favorite styles as it has a captured rod laid in the rubber bed that is firmly attached to the frame end, then the rod can be bent and welded onto the pipe as needed or a bracket can be welded on where needed to firmly blot it to the muffler or pipe. it can also be bent into a shape to accept one of those rubber donuts that you see on more mosern vehicle exhaust hangers https://www.ecsexhaust.com.au/exhaus...ber-mount-10mm like these https://www.canadiantire.ca/en/pdp/n...p.0128746.html you'll get it figured out once you get the pipes strung out under the truck. originally the systems may have been one piece but then they were probably hung before the axle went into the truck |
