Old 02-25-2024, 06:25 PM   #1
dmjlambert
dmjlambert's Avatar
For those who do, how do you gap spark plugs?
So back in the day I used the slotted bender built into the gap gauge to bend the electrode. But I have found on modern spark plugs the electrode is very hard and the slotted bender bends before the electrode and there is often not enough room to fit the slot of the bender in there to do the bend. On the last batch I clamped the electrode with vise grips and bent it, but it didn't feel very scientific to be doing that. What is the correct way? I know a lot of people just leave them gapped at whatever gap they are at when purchased, but sometimes I want do dial in my own preferred value. Considering how seldom I do this I'm not sure I would get some $100 tool for it, but perhaps I could.
Old 02-25-2024, 06:34 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: For those who do, how do you gap spark plugs?
Gee, I'm still using the included gapper hook on the feeler gauge. But then I insist on copper electrode plugs. No fancy-dancy platinum for me -- you can't clean it up with an ignition file. Also I'm only going to .045. Both trucks have HEI.
The old Craftsman key chain round gauge, with an inclined plane on the circumference edge might help you if you have a way to drive it between the tip and the ''claw.''
If I were a Pro, and worked in a shop, I could write off the expense of the $100 tool and impress customers with my mojo by using it. But otherwise, no thanks.
'68OrangeSunshine is online now   Reply With Quote
Old 02-25-2024, 08:27 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
I was a pro and worked in a shop and used the tapered tool, and the one with bits of wire on it. Electrodes weren't that tough, back in the day.
~Steven
Simi Valley, CA
Old 02-25-2024, 09:59 PM   #4
Rust_never_sleeps
Rust_never_sleeps's Avatar
I could never find the damned tool, I always used whatever pliers I found first
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is online now   Reply With Quote
Old 02-25-2024, 10:29 PM   #5
Sicklajoie
The Niner
Sicklajoie's Avatar
What the heck type of plugs are you using?
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 02-25-2024, 11:19 PM   #6
dmjlambert
dmjlambert's Avatar
Autolite 24 copper resistor plug.
Old 02-26-2024, 07:58 AM   #7
70STOVEBOLT
70STOVEBOLT's Avatar
I use the round gauge like 68OrangeSunshine described.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-26-2024, 08:33 AM   #8
I have alll three os these in my tool box, but tend to grad the flat blade one and it's tool as that is what I am use to using.
Old 02-26-2024, 11:37 AM   #9
MARKDTN
I have one each of these.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 02-26-2024, 03:33 PM   #10
weq92f
weq92f's Avatar
I like how Derek of Vice Grip Garage does it...
He looks at the new plug and says "gapped."
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-26-2024, 03:44 PM   #11
'68OrangeSunshine
I have those too. The top type is what I use most, but I also have a later one for HEI, with .045 as the smaller setting.
It also has a thicker, beefier bending hook.
Old 02-27-2024, 03:15 PM   #12
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I have those too. Pick what works at the time.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-27-2024, 06:11 PM   #13
bnorth
I find on newer plugs I am always closing up the gap a bit. Don't remember the last time I opened them. I use the round tapered gauge and just give a couple raps of the electrode on my vice to close them up.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
Old 02-27-2024, 08:30 PM   #14
dmjlambert
dmjlambert's Avatar
Do you insert the gauge at the setting you want while rapping it on the vice, or rap/measure/repeat?
Old 02-27-2024, 08:40 PM   #15
dmb
Active Member
dmb's Avatar
The old knife blade aint bad for opening them up. Also good for cleaning finger nails, cutting wire and getting viennia sausage out the can lol
dmb is offline   Reply With Quote
Old 02-28-2024, 01:12 AM   #16
'68OrangeSunshine
That last option is the most important.
Old 02-28-2024, 01:16 AM   #17
'68OrangeSunshine
If the gap's too close, I bend the thingie back with the hook, then measure. If now too wide, I give it a smack with a 3/8 Ratchet handle. My old Craftsman has a rectangular cross section handle. Figure 1/1000th per casual whack.
Measure again til it's there..
The important thing is not to spill the beer.
Old 02-28-2024, 08:32 PM   #18
bnorth
rap/measure/repeat
Old 02-28-2024, 11:42 PM   #19
dmjlambert
dmjlambert's Avatar
Thanks for the education, I'll fix up these spark plugs just right.
spark plug gap
