Rustoleum paint jobs
A work friend wants to paint his harlequin beater in Rustoleum paint to make it one color. While the car is a early 2000's Toyota Slow-Rolla it should last enough easily to be worthy of atleast cheap 2 part paint job. I offered him to use my yard if he brings it over sanded down. As I have a good enough compressor, and a couple of paint guns.
So my question is how long does Rustoleum last as a car paint in the southern california region? I get it if your painting a rat rod or something where the car won't last. Or just to get by while you do body work on a driver or project to keep it protected. |
Re: Rustoleum paint jobs
helped my shipmate rattle can his karmann ghia in the ball field parking lot at the end of the mole pier navsta LB summer of '91
semi gloss black turned out fairly decent, he painted an obtuse yellow triangle on the trunk lid up front for accent guess he didn't want it to be confused with all the other spray canned ghias in long beach ![]() not sure how long it lasted past the next year or two we were stationed together but was holding up last time I saw it good luck!
I started out with nothing - and I still have most of it |
#3 | |
![]() Join Date: May 2012
I sprayed it first with rattle can to get coverage. Then sanded smooth. Then I used the canned Rustoleum, same color, with a roller. When you use the roller it lays down flat and smooth. I was actually quite stunned at the results! It's holding up great. Not sure I would do my whole truck that way. Not that it looks that bad, but it is still quite an effort. You still have to prep and sand. Big benefits are: you save money on paint and touch ups of chips or scratches are easy to blend in. ![]() j
White K20 |
My dad and I built this car trailer back in 1967. It had always had a rustoleum paint job on it (until about 2 years ago).
Back then the paint held up pretty well. They must have changed the formula because it hasn't been as good as of late. Still ok for a trailer, though. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
I also did the inside of my pickup box, except I used a brush.
It's been fine. I think the biggest benefit in doing a vehicle exterior would be having it all the same color. K ![]() ![]() ![]()
Fairly long term results:
My truck was a painters work truck and was through at least 1 hailstorm. I filled most of the dings & dents and got tired of it looking like a work in progress. I shot it with Tremclad ( Canadian Rustolium) I bought the gallon can. I used a crappy little touch up gun. Had to cut it 50 / 50 with mineral spirits to get it to spray and used about 1/2 a gallon of paint for the whole truck. So, there wasn't much paint on it. When I first did it it looked pretty good actually. It was parked indoors when not on the road for several years and seemed like it was lasting. Then, I got divorced 9 yrs ago. Since then it's been sitting in the sun. Every year more of the red has disappeared. You can really tell places that got more or less paint. The picture of the left rear is where after a couple beers I grabbed a small foam roller and painted the bed side and tail gate. Straight Tremclad, no cut. That was 8 yrs ago. It's held up way better than the thinned out spray job. Probably because there's actually more than a micron thickness of paint there. It was a pretty thin single coat, and it has lost most of its shine though. I painted the interior with rattle can Tremclad. It looks really good and hasn't faded at all. Interior get less direct sunlight, but I think it's a lot better quality paint than the bulk stuff. This year I'm going to finish the last of the hail damage and do another paint job. Exactly what that means remains to be seen.
I got a bench seat baby, you don't have to sit over there. |
Rustoleum is alkyd enamel. Its good old paint.
Over time UV sun weather, alkyd enamel will fade though One Shot pinstriping/ lettering paint is alkyd enamel too Ive painted trailers , work benches I use Rustoleum semi gloss black on axles, frames wheel wells etc. Hold up great on undercarriages
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
I saw a "rustoleum" paint job in a magazine years ago, I think it was Hot Rod. They applied it with a roller and paint brush and did several coats. Then after it dried they block sanded it and buffed it and it looked pretty good!! I thought about it many years ago trying it on my '55 Chevy Belair but my dad said no and we sprayed it with RM Ditzler lacquer.
Take Care Troy |
