Junior Member
![]() Join Date: Oct 2022
Am I missing something?
Been cutting some of the floor out on my 70 C10 and noticed the 2 holes in the chassis rails (in picture), they line up with the trans crossmember, Looks like there should there be some fixings through them?
Thanks |
#2 | |
The Older Generation
Re: Am I missing something?
I'll check the 1/2 ton bare frame I have in the morning and see what is there. I think it should have bolts in it.
Born Psycho
![]() Join Date: Feb 2001
you sir are correct, a lot of times they don't get put back because the cab mounts get smashed down and it's a ***** to put them back in.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Here is a picture of my 1/2 ton frame.
Junior Member
Wrap a piece of masking tape on the nut. That will allow a box end wrench to hold it while starting the bolt.
Junior Member
Nothing wrong with welding....
![]() Join Date: Mar 2015
The early trucks had this end piece riveted onto the cross-member.
The only method to get it out was to hammer one side forward and the other back. This spread the frame slightly and knocked all kinds of dirt and crap loose in the process. Later ones were bolted. To get these out easier, I just loosened the bolts, at the cross-member, and removed the ones from the frame. Made it a lot easier to complete the R&R. The bolts came in from the top and I didn't have to remove them from between the frame and cab to get the cross-member out. I never did determine exactly when this change was made. Nothing wrong with welding to nuts to the top of the frame. Typically one doesn't have access to pull this off like you do. |
![]() Join Date: Apr 2016
Was this truck working without the crossmember attached? Trying to figure that part out.
Yes - a proper heading on your post
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
Junior Member
Ive only done about 50 miles in it since purchase but seemed to drive ok for a 53 year old truck, there are fixings on the bottom of of the crossmember too which are in place which was why I wasnt sure if top ones were supposed to be there or not.
Junior Member
#14 | |
![]() Join Date: Jun 2005
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#15 |
![]() Join Date: Sep 2014
