Old 08-22-2004, 02:15 PM   #1
Nightrider
Nightrider's Avatar
2wd lift ?
Does anyone know of a lift for the 2wd 1\2 ton? I know of a 78 Blazer 2wd 4spd that a would like to have IF I could put 33 inch tires on.
] : - 71' burb,5.3,4wd
02' f350.7.3
00' F250-powerstroke
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Nightrider is offline   Reply With Quote
Old 08-22-2004, 04:35 PM   #2
Staceydude
Staceydude's Avatar
If it was me I would Just buy a 4X4.... They are alot cheaper and easier to find right now.
The 2WDs are going up in value.
Either way I am sure you could lift it pretty easily.
Research some of the suspension sites under links.
Staceydude is offline   Reply With Quote
Old 08-22-2004, 09:17 PM   #3
Grim Reaper
You can get 33's on it with fiberglass fenders and no lift in fact you can get 35's on it.
http://www.mkparker.com/goose/
Check out that site. It has some info about fenders on it.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 08-22-2004, 10:39 PM   #4
NEVERENOUGH
NEVERENOUGH's Avatar
Go to fabtechmotorsports.com they have a very nice long travel two wheel drive kit for this model. Looks sharp and handles well I have heard. Good luck
NEVERENOUGH is offline   Reply With Quote
Old 08-24-2004, 05:22 PM   #5
Prerunner1982
Prerunner1982's Avatar
you could do a few things...
add lift coils, they make 3" lift coils.. add coils spacers.. a 3/4" spacer will give you a couple inches of lift. rear lift is easy, shackle flip, or new springs (best way) or blocks (cheapest way).
i run 32" tires with no rubbing, i do have HD coils springs so my truck has 0 rake.. sits level.. and i rolled the top lip of the fender, but it is so slight you cant even tell unless you look close. rolled it just enough to keep it from slicing up the tires like it was doing. feel free to message me if you need more info...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 08-25-2004, 12:52 PM   #6
loblazer
loblazer's Avatar
Nightrider, if you don't buy it. let me know how much it is? I would slam it!
loblazer is offline   Reply With Quote
Old 08-25-2004, 06:17 PM   #7
cochino12
It followed me home?
cochino12's Avatar
I saw a link on ck5.com that showed superlift ebay store scratch and dent 2wd lift coils for like $60 if that helps? I would have posted a link but I cant seem to get ck5.com to work right now. Its in the for sale board if you are interested
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-25-2004, 10:15 PM   #8
Staceydude
Staceydude's Avatar
Here ya go....
http://stores.ebay.com/Superlift-Suspension-Systems
Old 08-26-2004, 08:18 AM   #9
88Jimmy4x4
88Jimmy4x4's Avatar
Do you think that 2" lift coil springs would allow you to run a 33x12.50 on a 10" wide wheel with 4" backspacing without any rubbage?
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 08-26-2004, 12:49 PM   #10
Prerunner1982
i dont know about 10" wheels with 4" BS... my 32x11.50s on 8" wheel (not sure about BS) only barely rubbed until i rolled the fenders.. any wider and they would probably rub the lower part of the fenders.. here is a pic of my 32s this is with the wheel straight.. when turning there is less than 2 fingers width between tire and lower part of the fender..
