Old 08-22-2004, 10:04 PM   #1
chassispro
Drip Rail sealer question.
What sealer are you guys using to fill in the drip rail when you repaint your trucks? I've stripped my truck down to the metal, even remove the cracked old sealer in the drip rail. Now I need to put new sealer in.
Thanks in advance.
Scott
chassispro is offline   Reply With Quote
Old 08-22-2004, 11:23 PM   #2
64fleetside
3M self-leveling seam sealer, a two part sealer. You will need a special gun to dispense it, real cheap tho. Mask around both sides of seam after priming, fill drip rail, let set, paint. Brian
64fleetside is offline   Reply With Quote
Old 08-23-2004, 07:11 AM   #3
MACKL
Almost done!
MACKL's Avatar
3M drip check. Made for drip rails, hence the name. It dries overnight and is paintable. No special tools needed, just a steady hand...
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Old 08-23-2004, 10:48 AM   #4
Mixup
drip rail sealer
I used Drip chek and it worked great. I emailed #M and thats what they said to use.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 08-23-2004, 10:59 AM   #5
chassispro
Thanks for the suggestions guys. Looks like I'll go and get some drip check. Mixup, how many tubes did you use?
Thanks,
Scott
Old 08-23-2004, 11:31 AM   #6
Mixup
drip rail sealer
It took just about 2 tubes but I got 3 just in case.
1969 Z28 engine
Turbo 350
