05-14-2024, 09:36 PM | #1 |
C10 v. C20
So, are the 73-76 C10 and C20 bodies, beds, etc. the same? Basically, I'm looking for a truck to use for a full custom build that's going to be a complete chassis and drivetrain swap. About the only parts I'm keeping from the truck are the body (incl. doors, hood, fenders, et.) bed and bumpers. I see a lot more C20s in decent shape for reasonable prices vs. C10s, so if they're the same, I'll probably just get a C20.
05-15-2024, 06:40 AM | #2 |
Re: C10 v. C20
same stuff. just different frames.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
05-15-2024, 07:33 AM | #3 |
Re: C10 v. C20
If your location worries about emissions on that old a vehicle, C10s often had more emissions stuff then C20s. And light duty C10s more then heavy duty C10s. A lot of that stuff then was max weight based.
It might be a concern if the VIN you use comes off the cab. |
05-15-2024, 09:13 AM | #4 |
Active Member
Re: C10 v. C20
Other than the emissions, the difference between a C10 and a C20 is the frame. Both frames have the same dimensions, the C20 is a thicker gauge steel. Everything mounts in the same location on both frames. I personally have always looked for a 3/4-ton over a half ton because of the frame.
05-15-2024, 10:03 AM | #5 |
Re: C10 v. C20
Good info. Thanks!
05-24-2024, 05:58 AM | #6 |
Next!
Re: C10 v. C20
Frame specs
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
