#76 | |
![]() Join Date: Nov 2013
Re: Temperature sensor modification
It looks like all you will need is just a reducer bushing to make it function. Is this it?
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
#77 |
![]() Join Date: Aug 2004
Yes sir, that’s it.
I currently have an adapter but thought maybe I could get it to reach in there deeper. I heard about you and what your doing from Captn Fab so wanted to see if you could help.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#78 | |
It may be possible to modify the adapter bushing in a way that would allow the sender to go in further. Putting a counter bore in the bushing and tapping it deeper might get the result you're looking for, then again it may read correctly just as it is without any modification. I would try it to see if you get the correct reading. The aftermarket gauge might be better than the factory one.
#79 |
PM sent for payment info. Thanks
#80 |
Will go out today 11/30/23...tracking info sent via PM
Thank you!
#81 |
I’d like to get two senders for SVC late model heads to 76571.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
#82 |
just replied to your PM
