Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 05-22-2024, 02:28 PM   #1
70STOVEBOLT
70STOVEBOLT's Avatar
Top end cleaner that actually works
Does anyone know of a top end cleaner for GDI engines that actually works?
I bought a 2015 Silverado 1500 a couple of months ago and it's starting to idle a little rough. There are no codes for misfire, so I believe it is just carbon deposits in the intake manifold and valve pockets causing it. I tried Seafoam and have not noticed a difference. It does have 98K on it, so maybe it needs a set of plugs?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-22-2024, 07:00 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Top end cleaner that actually works
If Seafoam didn't help I would probably try this in the link below.
Link: https://www.amazon.com/CRC-05319-Int...63267395&psc=1
I have used Seafoam, and it helped several times.
Did you use the Motor treatment in the link Below?
Link: https://www.autozone.com/diy/perform...tment-used-for
The old Fuel injector cleaner that seafoam had was (NO Good)
Looks like the they have changed the label on the bottle.Link below.
Link: https://www.acehardware.com/departme...eaners/8038177
Lucas Fuel cleaner does not work well IMHO.
Side Note: Lucas oil Treatment is top Notch
The early bird gets the worm,
85 Chevy K-20
Old 05-22-2024, 07:11 PM   #3
70STOVEBOLT
I used the stuff in the metal can in your second link.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 05-22-2024, 07:44 PM   #4
Getter-Done
That stuff in the 2nd link is pretty good.
I have not used the CRC stuff in the first link.
Every product I have used of CRC's is Top Notch.
There are U tube video's on using this.
85 Chevy K-20
Old 05-22-2024, 08:50 PM   #5
Getter-Done
Here's a Video from CRC.
85 Chevy K-20
