Old 08-23-2004, 04:26 PM   #1
wwhijr
SUPERscrapMAN
wwhijr's Avatar
700r4 to 4L60 E swap
My 700r4 is having some problems and I am thinking about swapping it to a 4l60e. Would there be any advantage to this? How hard would the conversion be? I wouldnt think it would be a direct replacement, but i have been wrong before ( just ask my kids mom). I have heard that the 4l60 was a better tranny although I cant really complain with the service my 700r4 has given me.
Christine 1987 Chevy S10 2.8l 5 speed 600k miles! still chugging along - wifes ride
Old Smokey 1990 Chevy K1500 Suburban 6.2L Diesel - Banks sidewinder
The WarBeast 1994 Chevy Suburban K1500 - Semi retired at 400K miles
The BLueOx 1994 Chevy Suburban. K2500 454 Used on a daily basis.
wwhijr is offline   Reply With Quote
Old 08-23-2004, 05:29 PM   #2
Josh
He's got mean nasty FANGS!
Josh's Avatar
I would stick with the 700r4 aka 4L60 (4L60 is the technical designation of the 89+ ones, 4L60E is the designation for the electronically controlled valve body version) you have now. You can upgade but it would require new wiring/PCM and not sure what else.
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
6772chevycom@gmail.com
Josh is offline   Reply With Quote
Old 08-23-2004, 09:45 PM   #3
jeffs98
Trans swap
What is the truck priarily used for? How long did the 700 last??? What is it the complaint on the 700 now?? I build 700's all the time for people and if it has some updates put in it at the time of rebuild they are pretty dependable!! The thing that kills most 700's is either towing in od and/or not changing fluid and filter often enough!!
jeffs98 is offline   Reply With Quote
Old 08-24-2004, 04:41 PM   #4
wwhijr
SUPERscrapMAN
wwhijr's Avatar
The truck is for all intents and purposes a work truck. It regularly hauls 2 to 3,000 pounds. My biggest complaint right now is the pump is dying. It is singing a death song. It still seems to operate well for a tranny with 200K+ on it. I have kept up the maintainence on it. I had heard that the 4l60 was a better trans but after Josh's post I think I will just have mine rebuilt with all the heavy duty goodies in it and keep running it.
Old 08-24-2004, 08:23 PM   #5
patgizz
patgizz's Avatar
rebuild it, with a 13 vane pump kit, HD sun shell, good clutches and band, new thrust washers, and a towing shift correction kit, and you should be good to go. the only catastrophic 700r4 failure i ever had was the input shaft splines stripped off, but it had unknown mileage and was one of the weaker early units from 83.
patgizz is offline   Reply With Quote
