Old 05-27-2024, 08:49 PM   #1
Corts60
Just here to tinker
Corts60's Avatar
Picked up a 73 C20, low original milea
Well hello all!
I haven’t been on here much lately because I really haven’t been tinkering with my trucks lately….But! This weekend I picked up a 73 C20 with only 31k original miles! She lived on a farm in the middle of Illinois her whole life. I hopped in and drove it 240 miles home without a single issue. It has a 350/SM465. Not sure gears yet. I think 3:73.
Here are some pics after a quick wash and before I really started cleaning!
Old 05-27-2024, 08:52 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Picked up a 73 C20, low original milea
And here are some after I pulled everything out of interior and cleaned up 50 years of dirt. I brushed up loose rust and put corroseal on to stop it from spreading. I also scrubbed all the upholstery and the floor mat.
Old 05-27-2024, 08:55 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
Then I thought I would do a little buffing and get the front bumper looking a little better.
The plans are just to drive it and leave as original as possible. It isn’t perfect, so I can still use it as a truck and not feel bad about it.
Old 05-27-2024, 11:49 PM   #4
Greg58
Greg58's Avatar
Looks great! Enjoy!!
Greg
________________
1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd.
2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold}
1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400
2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax.
Greg58 is offline   Reply With Quote
Old 05-28-2024, 10:59 AM   #5
MusicMan70
MusicMan70's Avatar
Nice find and the bumper turned out great! I like that green as well, Congratulations on saving another one Cort!
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 05-28-2024, 12:45 PM   #6
Keith Seymore
Keith Seymore's Avatar
Noice!
If you find the SPID label I can probably tell you what rear axle ratio it has.
K
3.73 is standard; 4.10 and 4.56 optional:
https://www.gm.com/content/dam/compa...olet-Truck.pdf
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-28-2024, 01:01 PM   #7
Shifty One
Shifty One's Avatar
outstanding!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 05-28-2024, 06:23 PM   #8
Corts60
Just here to tinker
Corts60's Avatar
Originally Posted by Keith Seymore View Post
Noice!
K
Here you go! It doesn’t list the RPO for the axle. As you can see, she is a bare bones unit. The only options they chose was gauges and power brakes. It is a radio delete, lighter delete, everything delete truck. Haha.
Old 05-28-2024, 06:26 PM   #9
Corts60
Just here to tinker
Corts60's Avatar
Here are some pics of the engine compartment. Only things changed so far is radiator and HEI. I need to get some valve cover gaskets on her before I drive too much more.
Old 05-28-2024, 10:19 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
Wow. Such a killer truck.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 05-28-2024, 10:35 PM   #11
TKCR
TKCR's Avatar
Wow! Thats nice. I would have sworn that was a Pearl Gray interior, but the spid says Slate Green.
Old 05-28-2024, 10:51 PM   #12
jerry moss
Born Psycho
jerry moss's Avatar
Thumbs up Re: Picked up a 73 C20, low original milea
nice score, congrats.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 05-28-2024, 11:46 PM   #13
Dead Parrot
That MFG date of May 97 on the valve cover is interesting. Whatever the story is on the motor, nice looking truck.
Dead Parrot is offline   Reply With Quote
Old 05-29-2024, 06:30 AM   #14
Corts60
Just here to tinker
Corts60's Avatar
It actually says May 1973, you just can’t really tell in the picture. And thanks!
Old 05-29-2024, 07:18 AM   #15
ACS
That’s a great truck. Every now and again a nice farm 3/4 ton turns up. You got lucky.
What rear axle does it have? Semi or full float? If you’ve got a full float 3.73 that’s pretty nice with the 465.
I’ve got the same engine/trans combo is you (just coming up on 50,000 miles this summer) but with a 4.10 in the back. It turns a lot of rpm on the highway.
ACS is offline   Reply With Quote
Old 05-29-2024, 08:29 AM   #16
Corts60
Just here to tinker
Corts60's Avatar
Thanks! The rear is full floating. I just don’t know what gears yet. I drove it home at 60-65 mph and felt that was as far as I was comfortable winding her up without a tach.
Old 05-29-2024, 11:26 AM   #17
Dead Parrot
That makes more sense. It really looks original. I bought a replacement motor for my 75 around 97 and it was one of the black Hecho in Mexico 350s.
If that is the OEM exhaust system, make sure it isn't one of the double wall exhaust pipe setups on the y-pipe. If the inner wall collapses, all sorts of bad things happen.
Old 05-29-2024, 11:28 AM   #18
Corts60
Just here to tinker
Corts60's Avatar
Good to know! I’ll watch out for that. They pipe I’m pretty sure is original.
Old 05-29-2024, 08:07 PM   #19
Willowrun
Willowrun's Avatar
Always liked that color and ‘73’s are just cool. Nice truck!
Old 05-29-2024, 10:32 PM   #20
ACS
Mine still has the original Y pipe. What’s going to happen to it?
Old 05-29-2024, 10:34 PM   #21
ACS
Mine had the build sheet under the passenger side of the seat - tucked in the springs. My rear axle code is GT5, which is a full float 4.10
Old 05-29-2024, 11:27 PM   #22
Dead Parrot
IF it has a double wall pipe, the inner wall can collapse and block off the exhaust flow. Symptoms are crappy performance and carbs that keep going bad. My dad bought what is now my 75 in 78. Its performance sucked. It had problems going faster then about 60(during the 55 speed limit era). Plus the carb kept going bad and flooding out. The thing looked like a diesel going down the road. When the thermostat stuck shut, the head gasket cracked. Turned out to be a good thing. While the heads were off, I looked down the exhaust pipes and noticed that both were blocked off even though the outside looked normal. Took it to an exhaust shop and they said they had seen several of the newer GM trucks with that problem. Swapped to a dual exhaust and suddenly it ran much better. 90+ with more left(younger and stupider).
Don't know if the double wall Y-pipe was a converter thing to keep the exhaust hotter or a noise thing. Mine never had cats being a HD version but I can see GM using the same Y-pipe on both versions.
Old 05-30-2024, 07:47 AM   #23
Corts60
Just here to tinker
Corts60's Avatar
Thanks!
Old 05-30-2024, 09:40 AM   #24
Keith Seymore
Yep - if it's not on the SPID then it came with the base axle = 3.73.
No tellin' what's in there now.
K
1979-1986
1986 - 2019
Old 05-30-2024, 10:54 AM   #25
Corts60
Just here to tinker
Corts60's Avatar
K
Thanks Keith! So far as I’ve found, she’s basically 100% original. Still has the shocks on it that has the spirals in the metal. So I’m thinking still has the 3:73 as well.
