Molded Heater Hose Delete. Inlet/Outlet Jumper Hose
Any of you guys jump across the inlet/outlet and delete the water going to the heater core? If so you got a part number?
Oh Yeah, it's a 350.... Thanks! Last edited by Loose Screw; 06-05-2024 at 02:47 AM. |
Re: Molded Heater Hose Delete. Inlet/Outlet Jumper Hose
A short piece of hose does the job fine.
71 C-20 07 Magnum RT AWD |
![]() Join Date: Mar 2003
Just plug the holes with a fitting. There is already a by pass in the water pump via the hole below the bottom bolt. Just takes a tad longer to purge the air out. Most people jump with a hose b'cuz they can't get the fittings out or are just doing a temporary thing
I have a big ole loopty Doo on there right now. I was looking for something more stream lined like this---->
hose.JPG Anybody using this hose? |
#5 | |
port plug.jpg Thanks! |
Who's got steelies?
![]() Join Date: Feb 2006
No, you'll need something with a tapered pipe thread.
The threaded holes in the intake & pump where the hose nipples go are 1/2" NPT.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
#7 | |
Fitting.jpg Thanks! |
Who's got steelies?
Close.
That's a reducer, it will still have a hole in it. you need something like this: https://www.mcmaster.com/4638K514/
#9 | |
