Old 06-12-2024, 07:15 PM   #1
cigar-
cigar-'s Avatar
Need VIN help
I have an opportunity on a 1957 GMC C30 truck. Of course it has no title! The seller has very little to offer me so I am starting with the VIN situation.
He has sent me a photo of a plaque that contains a serial number and weight information. See photo attached/enclosed. My internet search tells me the VIN is located in three places on the frame. "IF" that's the truth, we know where to look.
What I need to know is how many characters are in the VIN for a 1957 truck? Is there a standard prefix? Like do all VINs begin with a series of numbers and letters? example 1S23Bxxxxxxxxx
cigar- is offline   Reply With Quote
Old 06-12-2024, 10:38 PM   #2
dsraven
Re: Need VIN help
the gm heritage center would be a great place to contact. they can send out a package with all the options it came with once they id where to look for a vin
this site may have the info on where to look. pick a year and check the manual index. likely all the same model of truck, say task force (55.2 to 59), would have the vin in the same place. driver's door pillar usually with a tag that is simply rivetted onto the metal.
https://chevy.oldcarmanualproject.co...esto/index.htm
this is the page for a 59
https://chevy.oldcarmanualproject.co...to/59tsn02.htm
Old 06-12-2024, 10:54 PM   #3
cigar-
cigar-'s Avatar
Re: Need VIN help
Thank you for the reply. Nice source for information. But.....they have assembled nothing for 1957 trucks at all so I cannot get any help there. I will hope and continue.
Maybe this cool old truck I found is not worth the work. I hate to see it get crushed!
Old 06-12-2024, 11:14 PM   #4
dsraven
Re: Need VIN help
the serial number on the door tag is the vin. they didn't have 17 digit vins back in the day.
this may help
https://www.stovebolt.com/techtips/series.htm
or this
https://talk.classicparts.com/thread...n-frame.13769/
Old 06-12-2024, 11:21 PM   #5
dsraven
Re: Need VIN help
and another
https://www.oldgmctrucks.com/page0290.html
what does your truck look like, good shape, not so good?
you coiuld check with the local authorities to see what can be done if there is no title. I'm from Canada so not sure how the different staes handle it.
Old 06-12-2024, 11:38 PM   #6
franken
Re: Need VIN help
The Nevada DMV website should have the info on getting a title. Nothing related to other states that the comments will have mean anything in your state.
franken is online now   Reply With Quote
Old 06-13-2024, 12:34 AM   #7
gmc jr van
Re: Need VIN help
They did not stamp the “VIN” on the frame until 1967.
The 1957 300 series had no prefix and 9 characters are in the “VIN” unless they built over 10 thousand trucks (303 C T 10000) at Oakland. The truck is the sixty first 300 model built at Oakland California for 1957.
It should have a Parts ID Plate on the glove compartment door.
gmc jr van is offline   Reply With Quote
Old 06-13-2024, 02:23 AM   #8
cigar-
cigar-'s Avatar
Re: Need VIN help
https://www.stovebolt.com/techtips/series.htm - didn't help as it's for Chevy trucks and not GMC
https://talk.classicparts.com/thread...n-frame.13769/ - helped a LOT! confirmed that the VIN system back then was not as it is now (as many digits). The serial number tells me its what should have been used as it describes the truck I am looking at.
https://chevy.oldcarmanualproject.co...esto/index.htm - does not have any 1957 truck information....no help
https://chevy.oldcarmanualproject.co...to/59tsn02.htm - again....it's for Chevy trucks not GMC. The coding system doesn't match up. The Chevy models are 4 digit while the GMC are one letter and two numbers. The one I am looking at is a C30.
Thank you all for your help. It is of great value for me to decide on this project.
Old 06-13-2024, 02:24 AM   #9
mr48chev
mr48chev's Avatar
Re: Need VIN help
Read what GMC jr van wrote ten times and forget what the internet BS artists say. They always claim that there are serial numbers aka vin on 49/59 Frames especially GMC but I have never seen one.
Print that photo and take it to the Nevada dmv and ask what it takes to get a title in Nevada. If there is an old license plate on the truck get a photo of that
If you do buy it do not under any circumstances remove that door post tag for any reason. That original tag with original rivets with original paint around it means that that part of the truck was never molested and starts are getting real hardcore about not approving one that obviously has that the tag removed even to repaint the truck. Also only that stamped serial number means any thing to the DMV on the tag although other info verify the info on the tag.
If you do buy it I suggest printing out or getting the Nevada bill of sale form and going to a Notary to have the signatures notarized. Or at least use that form. https://dmv.nv.gov/pdfforms/vp104.pdf
Engine serial numbers never match door post numbers on older rigs. They tell you that the engine was built for that year and size of truck but never match on Chevy or GMC trucks.
If you do an engine swap, transmission swap or rear end swap before having it inspected get bills of sale or receipts for those parts that show you obtained them legally and in good faith.
Some interesting reading here. https://dmv.nv.gov/pdfforms/vp022.pdf
My ongoing truck projects:
Old 06-13-2024, 02:44 AM   #10
cigar-
cigar-'s Avatar
Re: Need VIN help
mr48chev.....
Valuable information you gave. I have tinkered with old cars for a while and always make sure my butt is covered. NO shady Bill of Sale.....funny signatures, etc.
I have called the Nevada DMV about a bond title and the agent told me it's not worth it. I am wondering how and why she said that!
The tag on the truck will not be removed. I have a 54 5 window that was redone and the original tag remained!
We will see how this goes as I inch forward.
Old 06-13-2024, 10:27 AM   #11
gmc jr van
Re: Need VIN help
From 1955-1959 GMC truck series had 3 digits and some had one or more prefix F, M, S, PM and W. Starting in 1960 GMC truck series had 4 digits and prefixes. 1000 ½ ton, K1000 ½ ton 4/4.
The C30 would be a Chevy 1 ton model starting in 1960.
The truck you are looking at is a 1½ ton
Old 06-13-2024, 11:04 AM   #12
mr48chev
mr48chev's Avatar
Re: Need VIN help
Reading this the actual "hassle" is having to go to Carson City or conduct most of your quest there rather than at a field office. If I read your address right and read the map right that is a 50 mile run for you and my guess is that you probably go there reasonably often to shop anyhow. The hassles are listed here https://dmv.nv.gov/regbonded.htm
Big hassles if you live in the Vegas metro area as you either have to drive clear upstate or try to do it all by phone. The wait period while they do the research may be a hassle for some as it is not going to be a one day deal from the looks of it.
If the truck is close enough to run over and check and the seller lets you check it over I would go through all the hiding places looking for an old registration slip, Insurance card or anything else that might show previous ownership. I drug a "No title" S-10 Blazer home 15 or so years ago because I wanted the rear end and was going to chop the hulk up in small pieces to haul to the scrap yard a few at a time and when I flipped the body over and the glove box popped open and out fell a stack of papers and right in the middle of the stack was the title. An hour later I was at my friend's wrecking yard and he was unloading the body from my trailer with his forklift and sticking it in his crusher row. Bad part was that the rear end had a blown ring and pinion missing a lot of teeth and the gas tank was missing. I gave the axle to a former student who needed it for her son's S-10 4x4 that had a bent axle housing.
I'd open up the bonded title info in the link and decide one way or the other about if it is doable or too many flaming hoops to jump through. I don't think that the bond for 1-1/2 times the original list price of the truck is a big issue as that is a bond on about 4000 at most. Three years goes by fast when most of us are building a truck. I've heard about a couple of people who bought previously stolen vehicles who lost them when somehow the people who held title to the rig when it was stolen tracked it down and it had not been properly run though the system. I've never heard of or known of anyone who had someone show up and lay claim to the vehicle that they had a bonded title to though. It sounds like Nevada makes that a pretty safe thing anyhow.
Old 06-13-2024, 11:33 PM   #13
joedoh
joedoh's Avatar
Re: Need VIN help
i have two 55-59 chevy trucks and both have the vin stamped in the left frame rail just in front of the steering box.
i checked the one i just bought carefully because the title had a 56 vin and the cab a 58 vin plate. i made sure the frame vin matched the title vin before handing over the money. i didnt need to sand just wiped with my spit moistened thumb, numbers were right there. I suspected a cab swap because it has a 56 front clip and bumper and those dont fit well on a 58 frame without some work.
I will put up a pic of the one here at the house tomorrow.
Old 06-14-2024, 03:36 AM   #14
mr48chev
mr48chev's Avatar
Re: Need VIN help
This is what I have always gone by, The GM heritage center archives page for Chevy trucks. This diagram not showing any indication of a stamped number on the frame rail. Most reliable sources say that there were no serial numbers stamped into the frame until the late 60's
Old 06-14-2024, 08:35 AM   #15
1project2many
Re: Need VIN help
Folks often forget early GMC trucks were not rebadged Chevy trucks. Here's real info to help decode an early GMC VIN. This page gives the basic format for early GMC serial numbers. It's for pre- '55 2nd series but GMC used this format with small changes for the 55-59 "Blue Chip" trucks.
https://www.oldgmctrucks.com/page0010.html
This page (previously linked) describes what changed for the 55-59 trucks.
This page is to be used for more detail after determining the truck year and series.
https://www.oldgmctrucks.com/photos/...ies_YXTS_2.jpg
It looks like the serial number in your picture is for a 1957 GMC S305 "flat back cowl" w/ 195" wheelbase, 270 ci six cylinder engine, 2 speed eaton rear axle, 4 speed transmission, and hydraulic brakes w/ Hydrovac assist. Typically this chassis would be delivered to a bus manufacturer.
Here's one example of a 1957 GMC S300 "Flat back cowl" chassis:
1project2many is offline   Reply With Quote
Old 06-14-2024, 10:33 AM   #16
gmc jr van
Re: Need VIN help
Originally Posted by 1project2many View Post
it looks like the serial number in your picture is for a 1957 gmc s305 "flat back cowl" w/ 195" wheelbase, 270 ci six cylinder engine, 2 speed eaton rear axle, 4 speed transmission, and hydraulic brakes w/ hydrovac assist. Typically this chassis would be delivered to a bus manufacturer.
If it was a school bus chassis the serial number would be stamp S305. The serial number in the picture is 303. 155" wheelbase, 270 I6. The Parts ID Plate will show the Standard or Optional equipment it came with.
Old 06-14-2024, 10:44 AM   #17
mr48chev
mr48chev's Avatar
Re: Need VIN help
I full and well understand that part, Plus GMC trucks may have stamped serial numbers on the frame that Chevrolet never had from the factory.
Old 06-14-2024, 11:09 AM   #18
mr48chev
mr48chev's Avatar
Re: Need VIN help
I'd guess that the next thing is that we actually need to see photos of the complete truck.
155 inch wheelbase conventional cab flat back cowl chassis With a gross weight of 14,000 lbs is what is showing up. The chassis you normally see with a schoolbus body on it.
Old 06-14-2024, 07:08 PM   #19
1project2many
Re: Need VIN help
Fair enough. I followed the links I posted. The chart available for 300 series GMC trucks through those links has only one option for a T in the serial number.
Thanks for including additional information. Hopefully this thread can heklp folks in the future.
Old 06-14-2024, 09:15 PM   #20
joedoh
joedoh's Avatar
Re: Need VIN help
58 and 56 chevy frames
Old 06-14-2024, 10:40 PM   #21
unclebrad
unclebrad's Avatar
Re: Need VIN help
If that is on the driver side a little behind the alternator, that's where it is on my 55 too.
55 Cameo w/ 409/700r4
unclebrad is offline   Reply With Quote
Old 06-16-2024, 10:35 PM   #22
joedoh
joedoh's Avatar
Re: Need VIN help
yep thats where both of mine are.
funny to see the dead grass under the 56 big window (on 58 frame) compared to the green grass under the 56 small window i have had 3 weeks
