06-14-2024, 01:29 AM | #1 |
68 C10 brake booster to master cylinder rod to short
I believe that the rod from the brake booster to the master cylinder is too short. Does anyone know what its correct name is and where I could pick one up?
Thanks!
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
06-14-2024, 12:15 PM | #2 |
Re: 68 C10 brake booster to master cylinder rod to short
1970 C10 Custom longbed 350/350 |
06-14-2024, 12:22 PM | #3 |
sorry, that was a little broad, the Right Stuff R04 and R05 are examples of the kind o' thing you're looking for, you might find them from whoever made your booster too. Typically the booster comes with both, but sometimes you're left scrambling for a "gawd@mm1t"
https://www.summitracing.com/search/...tuff-detailing
06-14-2024, 01:13 PM | #4 | |
06-14-2024, 01:30 PM | #5 |
I bought this from summit (rsd-r05) after finding that my replacement MC was the deep variety where as my original one was shallow. When I got back to the shop I found its diameter was slightly too large to fit into my booster. I chucked the thing into a drill and using some heavy grit sand paper turned it down enough that it would fit! Then smoothed it out with 220 grit and she's working fine now. YMMV -Kevin EDIT: Only had to turn down the part that goes into the booster, not the whole thing. I don't think the o-ring does anything other than keep it from rattling around in the bore...I had to use a slightly smaller o-ring after turning that end of the pushrod as the one came with it was too large to fit into the booster.
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold Last edited by weq92f; 06-14-2024 at 01:35 PM. |
06-15-2024, 01:17 AM | #6 | |
Thanks for the info. I stumbled across a set at classic industries late last night and placed the order. When I go to pick up the truck I will be bringing my dewalt drill and some sand paper just in case.
06-15-2024, 08:21 AM | #7 |
Get one of these. The clearance needs to be just right.
https://www.amazon.com/Brake-Adjustm...125121019&th=1 |
06-15-2024, 07:23 PM | #8 | |
