06-13-2024, 12:05 AM | #1 |
Help Choosing Rear End Gear Set
When I swapped from 8-Lug to 5-Lug I found a used 1971 C10 rear end and put it in. She always had some gear whine but has now developed a bearing whine also. I always planned on changing the gears from the 3.07s in it to 3.73s so look like that time is now.
So my first question is which brand of gears are the better brand? What are people are having good luck with. I don't want junk. I have heard good things about Yukon gears, does that still hold true? What about Richmond? Second question. When looking at kits on Summit I found these two kits. But I can't figure out what the difference between them is? Can anyone help me out? Yukon P/N:YGK2227 Ring and Pinion Gears, GM 8.875 in. (12-bolt), Truck, 3.73:1 Ratio, 30-spline, Standard, Designed for Carrier Cases with A 3.73 and Up Gear Ratio, Kit https://www.summitracing.com/parts/y...ckup/year/1971 And Yukon P.N: YGK2228 Ring and Pinion Complete Kit, 3.73:1 Ratio, 30-spline, Standard Rotation, GM 8.875 in., Rear, Kit https://www.summitracing.com/parts/y...ckup/year/1971 |
06-13-2024, 12:21 AM | #2 |
20' Daredevil (Ret)
Re: Help Choosing Rear End Gear Set
Looking at Summit's website, the first one you posted, YGK2227, is for a 4-series carrier. YGK2228 is for a 3-series carrier.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
06-13-2024, 01:47 AM | #3 |
I've spent a couple hours as of late shopping for a set of gears for the 8.5 in my Blazer.
Maybe my research will benefit you.. The concensus that I've found is that Dana/Spicer, OE GM, and Motive Gear in the Blue Box get the thumbs up from most people.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-13-2024, 01:51 AM | #4 |
06-13-2024, 03:31 AM | #5 |
I used Yukon gears in the axle on my 94 when I switched to 3.73 from 3.42 after a failure. No problems after several thousand miles. Like about 2000-2200 rpm myself in final drive on a truck with overdrive. My custom high pinion D60 for the the 72 from East Coast Gear also has 5.13 Yukon gears. Purchased 5.13 Yukon gears from east coast along with an an ARB air locker for the AAM 11.5 axle retrofitted into the rear of my 72. Gears and air locker will be installed before I get the truck done.
If you have 3.07's currently you will need a need a new carrier or a thick gearset to go to 3.73's.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 06-13-2024 at 03:38 AM. |
06-13-2024, 12:18 PM | #6 | |
Does your rear end currently have posi? Or is that part of the change? I only ask as I have a open 3 series carrier in the garage I'd let go for shipping if your interested.
06-13-2024, 04:35 PM | #7 |
No posi currently, and actually really not thinking of upgrading to one. She is a cruzer so can't really justify the cost of adding posi.
From what I am gathering I should currently have an open 3 series carrier in my rear end right? |
06-13-2024, 08:28 PM | #8 |
The carrier to ring and pinion breaks are.
https://www.differentials.com/gm-8-8...t-truck-parts/ Carrier Breaks: 2.73 and Down; 2.76 - 3.42; 3.73 and Up So with a 3.07 ring and pinion you have a 3 series carrier. To run a 3.73 you have 2 choices. Replace the carrier with a 4 series carrier or, Use a 3.73 thick gear with your current carrier. See link below. https://www.ronsmachiningservice.net...lite-gear-set/ For what you have described I believe that most any popular brand would do what you desire as long as it was installed correctly. Here is a thread that has a post by someone who seems knowledgeable about the ring and pinion industry. Scroll to post #18. https://www.pirate4x4.com/threads/da...gears.2472305/
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 06-13-2024 at 08:37 PM. |
06-14-2024, 12:52 PM | #9 |
Excellent comments and advice above from HO455.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
06-14-2024, 03:13 PM | #10 |
Thanks for the link HO455. That was very informative.
Based in all this I think I will be looking to go with the Yukon 3.73 set that is designed for a 3 series carrier. Now.... how difficult is this rebuild? I have all the tools just never dine it before so a little apprensive. |
06-14-2024, 03:25 PM | #11 |
Read everything you can. Here are just a couple of articles on the Internet. I expect there are dozens or even hundreds more on YouTube. Some of them actually helpful!
https://www.randysworldwide.com/web_...l_Complete.pdf https://static.summitracing.com/glob...rp_install.pdf Finding instructions specifically for GM 12-bolt truck would be most helpful, but 10-bolt setup is virtually identical.
06-14-2024, 08:11 PM | #12 |
As an aside…
Another potential source for diff parts is your local gear and axel shop. I recently had mine looked over and a pinion seal replaced, and my old-school shop had TONS of very serviceable old metal rings, pinions posi’s,etc… I didn’t need any of it, but for someone looking for a less expensive option, this could help.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
06-14-2024, 11:37 PM | #13 | |
06-15-2024, 04:15 PM | #14 | |
Funny, I didn’t notice you were local til you said you might drive by!Lol.
06-15-2024, 04:26 PM | #15 |
The local mechanic that rebuilds my rear axle projects uses shims instead of the crush sleeve spacer to set the pinion pre-load.
06-15-2024, 10:40 PM | #16 |
Shoot. That is about 10min away from me. Looks like I will be making a quick drive by there next week. I have a call into M.I.T. for a quote but I have a feeling it is going to be more than my bank accoubt can cover. Thanks for the tip.
06-19-2024, 09:12 PM | #17 |
You bet!
Let us know what you find out.
06-19-2024, 10:09 PM | #18 |
Went and spoke with Steve at SD Axle and gear, and then also MIT Drivetrain since they were right down the street. Both were roughly the same price, SDA&G was alittle lower, but he also gave me the option of bringing in just the rearend and he would rebuild it on the bench. Thay knocked about $500 off the quote.
So now I have to find a day to pull the rearend and get it down to him. Thanks for the recommendation. |
