1967 GMC 930 Manual Trans Fluid?
The manual calls for “straight mineral oil gear lubricant”. I am not finding any locally. Does anyone know if there is a modern replacement for this?
Re: 1967 GMC 930 Manual Trans Fluid?
My Chevrolet Manual says SAE 80 or SAE 90 GR5.... Same for all manual transmissions.
#3 | |
![]() Join Date: Feb 2002
Also if you have an SM 420 transmission, with brass synchros, you want service GL-4. GL-5 has additives for limited slip [Positraction] but these additives attack brass synchros. ''Mineral Oil'' refers to natural petroleum oil, not Synthetic. In 1967 synthetic lubricants were rare. Much has progressed in this field since then, but if you want to go by the book, avoid them.
My dad was doing some reading and came across something that said to make sure there is no sulfer in it…?
![]() ![]() Join Date: Jul 2003
GL-4 80w90
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. ![]() 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Looks like this is what I am looking for. My dad did some more checking found someone that also recommends the GL-4. Most is GL-5 and not what the transmission wants.
Here is a quote from Penngrade oil.."PENNGRADE 1® CLASSIC GL-4 GEAR OIL SAE 80W-90 PennGrade 1® Multi-Purpose ‘Classic’ Gear Oil GL-4 SAE 80W-90 is a specially blended using high quality premium mineral base stocks and select additive technologies. It is designed to be used with “yellow” metallurgy (brass, bronze, copper) and other ‘soft’ metals used in synchronizers, bushings, thrust washers and other components typically found in classic manual transmissions and transaxles. In applications specifying API GL-4 quality lubricants, use of API GL-5 lubricants with higher extreme pressure additive activity/concentration can damage these ‘soft’ metal components." This makes perfect sense and I am confident now to replace the fluid with a GL-4. Thanks! |
Sounds good. Why was GM leery of multi viscosity 57 years ago?
They call for ''Straight'' oil.
![]() Join Date: Mar 2003
Right there. Have found out a couple of times when a customer has had their vehicle serviced elsewhere and then starts experiencing shifting issues. Drain and fill with GL-4. The GL-5 is too slippery for the brass rings to grab the gear and slow it down
Where do you pick up your GL-4, mech?
Supertrooper: What transmision do you have?
I just picked up a bottle of Valvoline GL-4 at my local Carquest. It was $13.
