Active Member
![]() Join Date: Jan 2015
68 inline 250/th350 complete runner
Complete running Chevy 250 inline 6 cylinder out of 68c10 pickup. Rebuilt at some time has brass freeze plugs. Mileage unknown but cant be much. Starts and runs as smooth as they come. Completely re-sealed valve cover, lifter covers, timing cover, oil pan. Used new grade 8 bolts in everything. New water pump, 160 degree thermostat, mechanical fuel pump, HEI distributor, plugs, build to fit plug wires, 1 wire 65 amp alternator, ebay polished 1 barrel carb w/electric choke, 153 tooth flex-plate, high torque starter and 7 blade clutch fan. Custom made fuel and vacuum lines. Turbo 350 rebuilt with a stage 2 shift kit. This is a running package and can be driven before purchase. It is currently in a 68c10. Could be sold with new radiator, shroud and hoses additional. I also have a Saginaw 3 speed with bell housing and correct starter for that. And a new 11” clutch and flywheel.
3000.00 Looking for a 4l80e for my ls swap. So consider trades Last edited by oneshotkyle; 06-15-2024 at 05:19 PM. |
Active Member
Re: 68 inline 250 complete runner
Another angle
That’s a real deal ! Good luck on the sale.
71 C-20 07 Magnum RT AWD |
Active Member
Active Member
Here’s what the main looked like
With the ridiculous costs to rebuild and the lack of reputable shops this is a no brainer.
Active Member
My buddy just had his 250 bottom end redone. All parts and machine work was over 2100 without assembly. This is a deal and excellent shape for someone. Plus you can hear it and ill take you for a ride in it before purchase
Active Member
Engine package will come with
Engine with th350 complete with Starter, alternator, hei, fuel, pump, carb, air cleaner and wiring to firewall. Also included is bellhousing, starter, saginaw 3spd, 3ott linkage all new and recently surfaced flywheel and new 11” clutch Already ordered a 4l80e so dont need that in trade thanks |
Active Member
Possible trades, looking for a couple things for my build
Holley 12.3 pro dash Boyd fuel tank Tilt column |
Have you posted this on eBay or CL ? Might open up the window of potential buyers.
Active Member
