![]() Join Date: Nov 2013
Fan issue with AC trinary switch
'67 C10 with '02 LS1
I'm running the Entropy LS swap radiator with dual fans. Fan 1 is wired to the PCM only, it triggers the relay at 195º, it works perfectly. Fan 2 is also wired to the PCM to trigger at 205º and it's also wired to the trinary switch and connected to the same trigger (ground). The fan will come on via the trinary switch or the PCM or both ( I assume) I'm getting a code P0481 (fan 2) when I have the AC on and the PCM triggers the fan 2 relay. I did find a loose connector in my load center for the fan 2 relay but I fixed that. I'm wondering if the trinary switch and the PCM fan trigger being wired together is causing the issue, and what is the best/easiest way to correct it?
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
Re: Fan issue with AC trinary switch
I rewired the fans and separated the PCM trigger and the trinary switch ground triggers
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() Last edited by A1971Blazer; Yesterday at 05:02 PM. |
computers don't like additional stuff. you need to wire it thru a relay were its either or, not wired together.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
thanks....see post#2
cool, thats how I was thinking just wasn't sure how to explain it!
