06-09-2024, 10:45 PM | #1 |
1968 GMC Window Regulator Repair
Hi... I need to replace the wheels on my window regulator. Looks like the originals were riveted on(?). What it is best way to replace these? Where can I get replacements? Are the new ones riveted on, bolt-on? Thanks!
06-10-2024, 12:30 AM | #2 |
Re: 1968 GMC Window Regulator Repair
I have seen the kits to replace the rollers but cannot remember where
But you are on the right track I bought replacements from lmc and they are junk
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
06-10-2024, 12:46 AM | #3 |
The little roller wheels used to be a kit. I think Brothers had them before the Holley buy-out.
In the Arizona sun, the rollers break up and turn to little square fragments you have to fight to roll up and down. I don't know if replacement rivets were included in the kit. I do remember a Regulator Spindle Drive Rebuild Kit. It gave you a fresh gear and ballbearings inside that dome with the window crank shaft [bottom of your pic] but you had to reshoot the three tiny rivets holding it together. Since there's more profit in selling new regulators, that item vanished.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 06-10-2024 at 12:52 AM. |
06-10-2024, 08:39 AM | #4 |
I bought the kit from Classic parts of America . Worked out very well comes with the rollers and the rivets the rivets are the hammer and dolly type . I used a cross pean hammer and a small socket to back up the rivet kit comes with the tool to start the mushrooming of the rivet
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
06-10-2024, 08:43 AM | #5 |
On my 1972, the gear was stripped, so no repair could be attempted. I used an aftermarket ACI unit from Amazon, and it's been good.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
06-10-2024, 11:02 PM | #6 | |
06-22-2024, 02:07 PM | #7 |
What is the best way to flare the rivets? They catch as soon as they start to flare. I've tried ones from LMC and Classic Parts. Both are the same.
06-22-2024, 02:24 PM | #8 |
If you have a set of Roll Pin punches that would get it started.
Link; https://www.amazon.com/TuffMan-Tools...%2C1842&sr=8-9
06-22-2024, 03:39 PM | #9 |
This is what came in the kit I bought
https://www.erivet.com/product_detai...itemNbr=HT-176 Looks like they don’t have the complete kit anymore but you can get it here or Amazon
06-22-2024, 06:25 PM | #10 | |
06-23-2024, 07:21 PM | #11 |
UPDATE:
I got the the new rollers installed. The passenger side is completely assembled now and the window rolls up and down beautiful. I started working on the driver side and when I turned the window crank to get the regulator to the position I wanted, the teeth popped out of the gears and now it's all wonky. Looks like new window cranks are available but how hard is it to mess with the wound spring, both getting it off and resembling it? Is it hard to do and are special tools needed? Should I just buy a new regulator? Thanks .. |
06-23-2024, 09:41 PM | #12 |
In a earlier post, I mentioned I had bought a pair of regulator gear repair kits. They had fresh gears in the metal domes and were to be secured by little rivets. Snap rivets might work.
I got them from Brothers [before the Holley buy-out] i think. You might also check GMC Pauls, and Truck and Car Shops of Orange CA. Winding back the regulator counterspring is daunting, and the reason I just bought a new regulator from GMC Paul.
06-25-2024, 11:49 PM | #13 |
Subscribed.
Good info!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
