#3676 |
![]() Join Date: Mar 2011
Re: PO has me PO'd
[quote=jaros44sr;9314975]I had thought of that but my crimp er has straight jaws and worried I would get some uncontrollable warpage
I could build new jaws if I could get the tool apart dang ![]() Jess, any pics of the vent windows yet? Guys thanks for stopping by[/quote] been busy darn job getting in the way ![]()
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#3677 |
Re: PO has me PO'd
Anyone have a parts book for this number not sure if its a speed minder or horn relay
#3678 |
Re: PO has me PO'd
#3679 | |
Re: PO has me PO'd
https://67-72chevytrucks.com/vboard/...d.php?t=808748 |
#3680 | |
Re: PO has me PO'd
#3681 |
Re: PO has me PO'd
Kinda like the newer trim
#3682 |
Re: PO has me PO'd
I gotta find some of these trim clips 2 parcels,but gives me patterns to find
Saw some on the classified, but wrong demention Lil shelf wear ![]()
#3683 |
Re: PO has me PO'd
This is my solution to faster reassembly on the rear flange
Picked up at McMaster Carr ![]()
#3684 |
Re: PO has me PO'd
Found some areas that need to be addressed
Old quickly repair Fibre glas Thinking 2 part epoxy ![]()
#3685 |
Re: PO has me PO'd
#3686 |
Re: PO has me PO'd
#3687 |
Re: PO has me PO'd
#3688 |
Re: PO has me PO'd
#3689 |
Re: PO has me PO'd
#3690 |
Re: PO has me PO'd
Orange ya glad I found my paint stick
#3691 |
Re: PO has me PO'd
Nice to be working with straight lines again
#3692 |
Re: PO has me PO'd
Needed a tool rest for the Dremel saw max to make a straight cut
#3693 |
Re: PO has me PO'd
Much easier to make a plunge cut holding Saw max against rest plus you don't have to put your face down by the blade to watch your cut
#3694 |
Re: PO has me PO'd
Had to put the tool rest back to stiffin the panel for the 3 J clips
#3695 |
Re: PO has me PO'd
Somehow holes in patch panel were 2 small for 8/32 Baked it up so I wouldn't hit the J clip
#3696 |
Re: PO has me PO'd
#3697 |
Re: PO has me PO'd
Finally found a clamp for uneven surface
