Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-28-2024, 01:20 AM   #301
Richard
Re: Restomod 72 K10 "Good Memories"
Originally Posted by ProjectDD View Post
Nice build, I enjoyed going through it. I like the seat idea. I have thoughts of something similar but with a full bench. I'd like to have "buckets" with spots for a submarine harness point for the passenger and driver and a normal spot in the center. For putting my son's car seat.
Thank you for the comment. Glad you enjoyed. I probably would have gone with a full bench, but this seat was free. The 88-94 seat design provides a lot more room in these cabs. Always liked a bench in a truck. My wife is under 5' so she can adjust forward on the passenger side with the 60/40.
Richard
Old 07-07-2024, 12:59 AM   #302
Richard
Picked up the seat today. I am almost never fully satisfied with results of work I farm out, regardless of the cost. Very happy with the results. Feels nice but I sit a bit higher than wanted now, I fully expected this with the foam work. Will shorten the seat mount brackets about 1"-1.5" My modified inner bracket for the 60 side needs an additional 1" chop. I sat them in the truck to see how they look. What do you think?
Richard
Old 07-07-2024, 01:30 AM   #303
57taskforce
All about them K’s
57taskforce's Avatar
Man Richard, those seats are incredible! I’m pretty jealous!
Tyler
Old 07-07-2024, 12:58 PM   #304
ProjectDD
Paint, Body & Metalworker
ProjectDD's Avatar
Seats turned out good. I definitely understand the not being satisfied with farmed out work.
ProjectDD is offline   Reply With Quote
Old 07-07-2024, 04:55 PM   #305
72 tigger
72 tigger's Avatar
Look like they belong!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 07-08-2024, 01:30 AM   #306
Richard
Very nice compliment, Thank you.
Thank you. Maybe my expectations are to high? IMO, If I am paying someone for something they do for a living. They should do better than I can do myself. I always pushed myself to be the best I could be in my career.
Thanks! Objective I am trying to accomplish with many of the modifications.
As I need to modify all four seat brackets now. I am reconsidering a custom frame that bolts to stock mounting points. Going to look at seat risers again and make a decision on which way to go.
Richard
Old 07-15-2024, 07:20 PM   #307
best view
You outdid yourself on these
best view is offline   Reply With Quote
Old 07-16-2024, 02:58 AM   #308
Richard
Thanks, they are starting to grow on me Steve Budy and his daughter did all the hard work. I provided the seat, material and he worked with me to achieve my vision. Maybe a slight variation of the original vision. I wanted a somewhat unique seat for the project that was comfortable, provided a bit more room and as said "looks like it belongs" I am very satisfied with the results.
Richard
Old 07-18-2024, 12:33 AM   #309
ProjectDD
ProjectDD's Avatar
I don't think so. Sounds like you're in my boat. I have found very few people in my life who strive for the quality, attention to detail I can see.
Old 08-09-2024, 12:20 AM   #310
Richard
Built a frame for the seats a couple weeks ago. Pushed through the heat and fabricated the mounts today. Want to add some gussets to the feet for more strength. Maybe get to that and cutting seat risers down this weekend.
Richard
Old 09-03-2024, 02:04 AM   #311
Richard
Have been working on the seats when I can. The three most difficult risers are modified. Inner on the 60 side need chopped still. I took over 4" out of the risers to get the drop I wanted. Had to order hardware online to complete the install. No one here in California seems to have more than a couple of bolts in stock. Pretty sure I know who to thank for this ridiculousness.
Richard
Old 09-11-2024, 02:16 AM   #312
Richard
Wow! over 100,000 views now. Thanks to all for the interest in my project. It has been really hot here, 114 degrees +. Would love to see some more comments. To hot for me to get any work done. My work place is at least 10 degrees lower and is somewhat tolerable. Supposed to be cooling down by end of week and may get on finishing the seats.
Richard
Old 09-11-2024, 09:17 AM   #313
NDM
What steel is it that you used? I need to make a seat riser for my seats out of a Mercedes R350.
NDM is offline   Reply With Quote
Old 09-15-2024, 01:13 AM   #314
Richard
Just used a mild steel 1" square tube I picked up at Ace Hardware. Did not see a need to go way overkill. Only needs to support 3 people and the seats. Seat belts are are floor mounted in the truck. If I was installing seats with integrated belts a thicker wall tube would have been ordered and used. Should finish up all mounts tomorrow.
Richard
Old 09-15-2024, 07:58 AM   #315
NDM
Nice. Thanks
My rear seat brackets are way overkill at 3/8 inch thick. Those are integrated belt seats from the third row of a cadi/suburban. I will likely go with 1/4 inch for the front brackets.
Old 09-16-2024, 12:15 AM   #316
Richard
Nice. Thanks
Should have mentioned I used 1/4" steel for the feet. The gussets and box plates on the mounts are 3/16". Fully finished finished the seat mounting today, last riser and feet of frame boxed in. It is ready to bolt into truck as the original bench went in. Will most likely do a beauty cover for the sides now.
Richard
Old 12-08-2024, 02:40 AM   #317
Richard
Working on wiring when I can. Still to much work time at the shop. I installed the headliner and trim. Think it looks nice. Was going back and forth on whether or not to use it. No holes were drilled in cab to install so I can remove later if I choose.
Threw the dash pad on just to see how it fits. It is an OEM type replacement I purchased in 03 from Dashes Direct. I know a parchment dash pad was never offered by GM, but that is what I wanted.
Took my door panels to the shop, cleaned, prepped and painted them. Used the SEM "super white" that was recommended. They are more white than the parchment. Do not know of any other choices at this time.
Richard
