Old 06-30-2024, 07:39 AM   #1
1967GMCC20
1967GMCC20's Avatar
Increase 1967 C20 3/4 ton load carrying..
Add load carrying capacity. Extra Springs?
I will add front sway bar.
I can carry 200gal water fairly well. Tank is back due to tool box.
Like to be able to safely haul 300gal.
1967GMCC20 is offline   Reply With Quote
Old 06-30-2024, 09:21 AM   #2
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: Increase 1967 C20 3/4 ton load carrying..
Adding a rear sway bar would help too, but that's really a job for a 1T truck, since the tank's over a ton when full.
~Steven
Simi Valley, CA
Old 06-30-2024, 09:54 AM   #3
72c20customcamper
72c20customcamper's Avatar
What’s the GVWR in the plate? My 72 c20 is 7500 lbs the truck itself is less than 5k . So over 2500lbs capacity that’s the approx weight of 300 gallons of water . I would go from there .
Lots of limitations on old trucks . Age of the springs and axles is one as is the braking system. Drums would have a lower ability to stop a fully loaded truck . But modern E rated tires are better than old bias plies so that’s a plus .
Also 4x4 trucks usually have less payload and GCVWR because they are usually heavier than their 2 wheel drive counterparts.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-30-2024, 10:51 AM   #4
PbFut
If you have leaf springs, find a set of Helwig helper springs. I rolled across the dump scales many times over 10k hauling broken concrete about 15 miles. Obviously way overloaded, it was 45 yrs ago and I was invincible. Put many more miles on the truck after that project. 71 c20 custom camper. These trucks are mighty strong but know you are taxing every part of a now 55 year old rig.
PbFut is offline   Reply With Quote
Old 06-30-2024, 11:49 AM   #5
Getter-Done
Getter-Done's Avatar
Here is the most economical set of Helper springs that I found on a quick search.
Link: https://www.truckspring.com/products...elper-991.aspx
Summit had some better sets that cost More.
The early bird gets the worm,
85 Chevy K-20
Old 06-30-2024, 04:59 PM   #6
1967GMCC20
1967GMCC20's Avatar
Thanks, great points.
I like the helpers,I ve used hellwigs on my 2006 1500.
My drum brakes work good, PO added hydraboost system. 4.57 gear helps up hill.
I might stick to 250gal.
Old 06-30-2024, 11:48 PM   #7
sloGMC
I added Timbren "rubber springs" to assist my 2000lb leafs. I think the kit was not designed for leaf suspension, so the mounts didn't work at all and I had to fabricate my own. Kind of a pain in the ass but I'm really happy with the results.
It still rides like a couch and now I can haul a full yard of dirt or rock without the rear getting all sad and squatty like a Carolina truck or whatever.
1971 Pontiac Firebird
1971 GMC C2500
sloGMC is offline   Reply With Quote
Old 07-01-2024, 08:33 AM   #8
1967GMCC20
1967GMCC20's Avatar
My CG for water tank being pushed back from tool box, hurts some.
My Chev 2500HD 4dr long bed can haul 425gal tank full. It's a truck.
It carried my 3200lb Lance camper "geared up" and towed Chevy wagon
Old 07-01-2024, 09:55 AM   #9
Getter-Done
Could you change to side mount toolboxes and still have room for water tank and tools you need?
85 Chevy K-20
Old 07-01-2024, 10:02 AM   #10
1967GMCC20
1967GMCC20's Avatar
Probably could move tool box, easier to use big yruck, and settlt for 250gal max.
I heard sway bars are a .yst on front end.
. I had a trailer 3500lb single axle,buy that was a mess on wash board road.
Old 07-04-2024, 07:19 PM   #11
1967GMCC20
1967GMCC20's Avatar
Drove it 50mi today, getting ready for 200mi round trip soon.
Old 07-04-2024, 07:30 PM   #12
Wikid61
Wikid61's Avatar
Shocks? New or rebuild (bushings)
Wikid61 is offline   Reply With Quote
Old 07-05-2024, 06:31 PM   #13
425HP409
425hp409
425HP409's Avatar
I have a set of factory overload springs that you can have if you pay the shipping. They have all the mounting brackets etc.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Oldsmobile 442, all original
425HP409 is offline   Reply With Quote
3/4-1 ton 2-wd, long bed
