07-13-2024, 12:21 AM | #1 |
GM Truck Headlight Wiring Sockets
Found these GM sockets replacement on EBay, that fit my 1983-86 trucks ( probably other years too). They allow you to remove original headlight wires from old/broken sockets, and install original headlight wires in new sockets. Have done two sockets so far. Use a Home Depot Husky #2.0 straight screw driver, from a small screw driver set, and small hammer. Place the replacement socket w/wires in open vice, with socket on top, wires hanging down through opening. Lightly tap screw driver to release wire. The original do in truck. For me, most will not release by hand. Will post a couple of photos of process soon.
Below is the eBay listing used. Posted this thread because they allow you to replace sockets with original wire/clip. Hope this helps. GM Truck Headlight Wiring Sockets- For Low & High Sealed Beam Bulbs- 4 pcs- #044 Note: The wire is released from socket by pressing wire tab closed, photos showing tab and its location soon. IMPORTANT!——see posts below for better information on Packard part numbers and terminal connectors purchasing!! Photos: - first two show original and new replacement from this set; - third and forth the screw driver used; and - last new socket w/wires removed. Last edited by aotte1; 07-13-2024 at 11:35 AM. |
07-13-2024, 01:03 AM | #2 |
Re: GM Truck Headlight Wiring Sockets
Second set photos
- one and two show placement of screw drive, before light hammer tapping; - second show better screwdriver placement on 2 wire, the 3 wire socket center wire is opposite the two outer wires; - three and four show completed new socket with original wires; and - five is replacement as received. Last edited by aotte1; 07-13-2024 at 01:12 AM. |
07-13-2024, 01:15 AM | #3 |
Last photos
- first is original sockets after living in AR it whole life, along with wild animals chewing some; - second is terminal kit that did not work; and - last is eBay listing. New note added, see post below for other option on purchasing original type white terminal connectors. Thanks to Hatzie for information on original Packard part numbers. Last edited by aotte1; 07-13-2024 at 11:45 AM. |
07-13-2024, 10:12 AM | #4 |
Moderator
OE headlight sockets take Packard 59 terminals
1209344030 is the Packard 59 extractor. It's got a purple handle. The Packard 56 extractor has a green handle. I picked up several Delphi Packard extractors in some yard sale tool boxes. You can make them with a grinder out of peanut butter screwdrivers. I've found the little green handle Xcellite precision screwdrivers work as well cuz the shaft of the screwdriver is'nt any larger than the sides of the flat tip. 02973215 is the Packard 59 terminal sized for 16 to 18 AWG 2965810 is the three terminal black Packard 59 connector shell for the H4 sealed beams. 6288471 is the natural color three terminal Packard 59 connector for the H4 sealed beams 6288472 is the natural color Packard 59 connector for two terminal sealed beam headlights
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
07-13-2024, 10:53 AM | #5 |
Hatzie,
Thanks for adding more useful information. Note: Mouser Electronics sell both the 2 and 3 terminal connectors, 6288472 and 6288471 in white. These are made by the company that purchased Delphi-Packard, maybe APTIV? I just purchased some of both. Will report once received. Les Last edited by aotte1; 07-13-2024 at 11:46 AM. |
