Old 07-16-2024, 09:15 PM   #1
Loose Screw
Loose Screw's Avatar
Distributor/Points etc etc
Fixed!
Loose Screw is offline   Reply With Quote
Old 07-16-2024, 10:06 PM   #2
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: Distributor/Points etc etc
Working solo, I've strapped down the trigger on my timing light and laid it on the cowl so I could see it from the driver's seat. A plug tester would work also.
This way I could see when I at least had enough gap to make some kind of spark
Once I got it to run badly, I could set dwell with the meter, then set initial timing.
I had this problem because I had the type of points with the condenser onboard which got in the way of the feeler.
You might just be able to get a paper match in there for initial gap the old school way.
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 07-16-2024, 10:08 PM   #3
Rust_never_sleeps
sanding the points with a little bit of Emery paper first is a good start
Code:
            __
     ______|__]\____
Old 07-17-2024, 12:31 AM   #4
Loose Screw
Wired the Distributor wrong!
Old 07-17-2024, 01:34 AM   #5
Rust_never_sleeps
Yeah, that prolly didn't help ;-)
Code:
            __
     ______|__]\____
Old 07-18-2024, 08:43 AM   #6
1967GMCC20
1967GMCC20's Avatar
I have wired coil backwards before.
I've also taken several coils to test spark. And once the most beat up, dented coil I had was best.
1967GMCC20 is offline   Reply With Quote
