Old 07-17-2024, 06:23 PM   #1
72c20customcamper
72c20customcamper's Avatar
Outer lock nut torque 85 K20
I’m getting conflicting torque specs for the outer lock nut on the front hub . Some say 160-200 ft lbs and others say 60-75 ft lbs . I don’t have a shop manual but my procedure was spin the hub as I torqued it to 50 ft lbs . Backed it off and torqued to 35 and backed it off about a little to line up the pin up to the lock washer . Installed and torqued the outer to 75ft lbs but I’m thinking maybe that’s to loose ?
Should I take it apart and retorque ?
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-17-2024, 09:45 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: Outer lock nut torque 85 K20
What you did should work just fine. I usually range any where from 35-50 final torque depending on how everything feels, and the axle I’m working on. The outer nut should be fine at 70.
Tyler
Old 07-17-2024, 10:22 PM   #3
Getter-Done
Getter-Done's Avatar
What you done sounds good.
I hope you greased or replaced the Inner spindle bearing while you had it apart.
Picture for Reference.
84 Chevy K-20
Old 07-18-2024, 08:52 AM   #4
72c20customcamper
I did not the front axle was rebuilt before I bought it . I guess when I do the other side I’ll pull the spindle and look at it . Not even sure I’ll have to replace anything on the passenger side . Everything was well greased on the driver side but the cup was spinning . So it may be just a repack
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-18-2024, 09:10 AM   #5
72c20customcamper
Never use the 4 wheel drive so the axle is never spinning . But now you got me thinking . I just ordered new axle spindle bearings and the OTC 7502 spindle tool . Guess I’ll be changing them out .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
