Old 07-20-2024, 11:17 PM   #1
J_T
When you change your a&b pillar how do you get to these bolts?
My rocker boxes are solid, but the very tip of my a pillar is rusted so I'm going to replace it and I think I'm going to replace The back part against the rear fender... But there are two bolts from the inside that I can't get to because they are inside the rocker boxes which are solid. They will be removed because I am replacing that inner metal of the inner rocker. Do y'all fool with these or do you just weld them solid?
J_T is offline   Reply With Quote
Old 07-21-2024, 02:56 AM   #2
1970cstblazer
1970cstblazer's Avatar
Cool Re: When you change your a&b pillar how do you get to these bolts?
When I replaced the complete RH bedside on my 1970, I was able to access the two rear bolts by removing the bolted on end cap on the rocker box. The front two are not accessible unless the entire rocker box is removed. Those were installed prior to the rocker box being welded on at the factory.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
