Old 07-21-2024, 06:06 PM   #1
chris989
can not locate ac freon leak.
Hello all,
1989 v2500,,,5.7
This is my 3rd time trying to find this leak,,, after converting to sanden, the system will pull a vac and hold over night. But when charged it will lose the freon after a week or two.
I then charged the system to 100 psi and it will hold forever. I replaced a suspect oring and charged.. 2 weeks,, low on gas.
It is not charged to 100 psi again,, and it will hold,, but i know it will lose gas afterwards,
Is it possible a leak presents itself when the metal expands or contracts in the evap or condensor due to temperatures??? Any guesses
chris989 is offline   Reply With Quote
Old 07-21-2024, 08:01 PM   #2
72c20customcamper
72c20customcamper's Avatar
Re: can not locate ac freon leak.
Have you added dye to it . I had a similar issue with my 85 it ended up being the compressor seal
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 07-21-2024, 09:25 PM   #3
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: can not locate ac freon leak.
at work we always add dye to the system and go over everything we can see with a black light before we release the vehicle back to the customer then we have them come back in a few days and check it again.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 07-21-2024, 09:33 PM   #4
chris989
It has dye and i can not see any traces, The compressor is a new real sanden 4711 sd7
my gauges are Yellow jacket analog,
I have had a charge of 100 psi for 4 hours now and still dead on 100,
shop has AC and temperature is a steady 72. I ordered a new condenser and evap core but hate to go through the work to not have it solve the problem..
it has all new Galaxy hose (usa) and fittings,
My gauge is hooked to the filter.dryer,,, I can only think that when i remove it the schrader valve is leaking and with the gauge it is captured,,, I have soaped it with no bubbles.. I might hook a hose to the shrader and put the other end in a cup of soapy water??
Old 07-22-2024, 09:41 AM   #5
Dead Parrot
I have had good luck with the R12 version of this: https://www.autozone.com/a-c-chargin...2oz/370967_0_0
Replaced a compressor in the mid 90s and used one of those cans with oil, leak finder, leak sealer and freon. Only needed a couple of cans since until something failed in the back of the compressor a couple of years ago. A large oil stain implies something that exceeded the capacity of the leak stop to fix. Planning on doing a Sanden conversion at some point.
Might be worth a try of the R134 version.
Dead Parrot is offline   Reply With Quote
Old 07-22-2024, 02:05 PM   #6
chris989
Made it to the shop today,,, AC off,, temperature is 85 inside the garage,, The AC system has 106 psi,, It gained ~6psi due to ambient temp....
I will cool the garage back to 74 and see if it equalized back to 100psi,,, If it does,, I guess i will charge the system again and cross my fingers?
Old 07-22-2024, 08:28 PM   #7
hatzie
Moderator
hatzie's Avatar
I always change the service valves when I work on AC.
Giving the condensate puddle on the driveway a once over with the blacklight might reveal an evaporator leak.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-23-2024, 08:06 PM   #8
v30crewcab
v30crewcab's Avatar
I had one slowly leaking down. pulled the valve core out of one inlet and it was missing the little sealing gasket on it. put a new one in and good to go.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 07-24-2024, 07:15 PM   #9
chris989
Update,
Charged the system and sure enough it leaked even after holding 100 psi for over 30 hours.
Today i started pulling it apart.. I removed the shroud and leaned the radiator back and sure enough there is dye on the radiator.. Using the blacklight and glasses i can see a stain on the condenser although not green. A few green drops appear on the engine radiator..
My guess is when it gets hot and builds over 200 psi a tiny pinhole leaks and the fan/wind pulls it into the radiator..
Anyway,,, pumping it back down again with a new condenser. I took a few pictures but it doesn't show anything
Chris
Old 07-25-2024, 04:54 AM   #10
jjzepplin
jjzepplin's Avatar
In For results.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-25-2024, 11:26 AM   #11
chris989
Originally Posted by jjzepplin View Post
In For results.
the new condenser is smaller and thinner than the OEM. When i started the truck i noticed the high pressure nearing 375 and that is not average for this build.
THe fans shrouds were off and I hope that is the factor.. I will run the truck toady and check vent temps..
Old 07-25-2024, 03:12 PM   #12
hatzie
Moderator
hatzie's Avatar
Is the filter in the orifice valve full of crud?
What's your low side pressure running?
