Old 08-24-2004, 08:50 PM   #1
Bigdog257
Question gettind rid of tailgate chains
Does anyone have any suggestions or modifications that they have done?
Bigdog257 is offline   Reply With Quote
Old 08-24-2004, 09:26 PM   #2
CHEVYE
my gas saver
CHEVYE's Avatar
depends if you want it to be functional or not? they make sleeves for them. my buddy hooked his on another hook @ the bottom so they won`t swing. if you don`t want a chain just put a bolt in it or shave it up.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 08-24-2004, 09:28 PM   #3
Alexis
Member since 2000
Alexis's Avatar
why not use some straps from a newer chevy or have some made?
Alexis is offline   Reply With Quote
Old 08-24-2004, 09:43 PM   #4
Don Smith
The best chain replacement kit I have seen is one by WOW Products @ www.wow-products.com
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 08-24-2004, 10:46 PM   #5
highboy_04
highboy_04's Avatar
what about the cables like newer fords with a set belt to hold the gate shut. if i can find it i will get a link from the 60-66 board.
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
Old 08-24-2004, 10:52 PM   #6
highboy_04
highboy_04's Avatar
here is a link if it works to the seatbelt latch idea. good luck. http://67-72chevytrucks.com/vboard/s....php3?t=103492
'67 c10 350/th350
Old 08-25-2004, 08:24 AM   #7
Bigdog257
Thanks for the help. I like the boat latch also, That looks easy enough. Just drill a couple holes and your set.
Old 08-26-2004, 12:28 AM   #8
nate68
tailgate? i took mine off years ago. have no use for it
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 08-26-2004, 04:33 AM   #9
68LSS1
68LSS1's Avatar
I like the Mar-K kits. Not cheap ($405.00) but you get a new tailgate (your choice of flush smooth or Bowtie), caps for the bed sides, linkage/hardware and a internal handle. can't link directly to page. Go to Mar-K , then select tailgates, and then you'll see a bunch of different options. There is two in the list that say "with handle and latch mechanism" in the description. Click on one of them for a picture.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
