Old 04-24-2024, 07:09 AM   #101
hewittca
hewittca's Avatar
Re: 1970 C10 ChassisFab Build Thread
Nice job on the tubs. Did you have to get extra tubs for your filler piece? When I did mine I used scrap that I cut out of my inner bed sides when I raised the floor. I still need to finish welding my tubs, it's been over a year!
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 | Oscar the 70 C10
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 04-25-2024, 11:41 AM   #102
nicklear36
nicklear36's Avatar
That's super clever I hadn't even considered that! I did buy two tubs for each side... I wish they still made CHUB TUBz in the stock wheel width
nicklear36 is offline   Reply With Quote
Old 04-27-2024, 08:20 PM   #103
nicklear36
nicklear36's Avatar
Fitting some pieces for the raised fiberglass inner fenders
Old 04-27-2024, 08:40 PM   #104
clay68c10
clay68c10's Avatar
Nice clamp usage! Those pieces aren’t going anywhere
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-11-2024, 08:28 PM   #105
nicklear36
nicklear36's Avatar
New tailgate fits alright! Working on the bed floor, rear tubs, and tailgate filler panel.
Old 07-12-2024, 09:18 AM   #106
loudchevy
loudchevy's Avatar
Where did you get the tailgate from?
Scott
1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 07-12-2024, 11:29 AM   #107
nicklear36
nicklear36's Avatar
LMC for nearly all of my parts
Old 07-12-2024, 11:46 AM   #108
loudchevy
loudchevy's Avatar
How did it line up with the bed sides? I need a tailgate, not sure if I want to go the LMC cheaper route or pony up and buy an OG old metal tailgate.
Scott
2003 Tahoe Stock
Old 07-14-2024, 10:58 AM   #109
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Shes coming along...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-15-2024, 07:28 PM   #110
nicklear36
nicklear36's Avatar
I can't complain with this one from LMC. I used the stock hinges and handle with it to make it feel more "solid" like the original
Old 07-22-2024, 05:36 PM   #111
nicklear36
nicklear36's Avatar
Trying something different with the tailgate filler panel. This is an inner tailgate skin. It's gonna take a fair amount of fit and finish back here, along with installing the emergency shrader valves and remote battery posts.
Old 07-23-2024, 11:19 AM   #112
loudchevy
loudchevy's Avatar
Is that panel left over from the original tailgate? If so great re-use of material.
Scott
2003 Tahoe Stock
Old 07-23-2024, 01:47 PM   #113
zicc1835
zicc1835's Avatar
WOW factor..... great Idea !
zicc1835 is offline   Reply With Quote
Old 07-23-2024, 02:50 PM   #114
nicklear36
nicklear36's Avatar
It's a new piece, I had it for a long time actually thinking I was gonna salvage the old tailgate.
I might trim off the dented part near the bottom or tack some new sheet metal right there.
Old 07-26-2024, 08:35 PM   #115
nicklear36
nicklear36's Avatar
Inching along
Old 07-27-2024, 12:21 AM   #116
chewychevy67
First thing I thought in that picture on a Friday night is.... what's in that cooler in the back lol. But that is a Purdy Orange small block!
chewychevy67 is offline   Reply With Quote
Old 07-27-2024, 01:40 AM   #117
nicklear36
nicklear36's Avatar
Summer essentials
Old 08-05-2024, 07:07 PM   #118
rodstored-72
chevy truck fan
rodstored-72's Avatar
I would swear that is a model engine & not a 1:1 real engine!! very nice detail... and overall build....
rodstored-72 is offline   Reply With Quote
Old 08-06-2024, 01:10 AM   #119
68bowtie
68bowtie's Avatar
Inching along
Wow that’s clean
Old 09-12-2024, 03:28 PM   #120
nicklear36
nicklear36's Avatar
AC Condenser going in
Old 10-22-2024, 11:42 AM   #121
nicklear36
nicklear36's Avatar
Got the rear tubs in place. I need to trim a little from the inside since they are rubbing the outer bedside skin. After this, I noticed the bedside rails at the top of the sides are bowed out on both sides.
Has anyone had to straighten this area? I'm thinking a long 2x4 and big hammer whacking towards the top of the rail will straighten it a bit.
Old 10-22-2024, 03:38 PM   #122
loudchevy
loudchevy's Avatar
That bed turned out great. Not sure about a 2x4 and big hammer, but maybe a piece of angle iron and some clamps to help bend it back in. Is it like that on both rails?
Scott
2003 Tahoe Stock
Old 10-22-2024, 03:53 PM   #123
nicklear36
nicklear36's Avatar
Thank you! Yeah my plan now is to weld some angle iron to the inside of each bed rail and use a slide hammer to pull inwards after thinking about it some more.
It was a farm truck so the PO must have had some heavy stuff rolling around in the bed lol.
Old 10-22-2024, 09:37 PM   #124
zicc1835
zicc1835's Avatar
can you tell me who's AC kit your using my cab is a non AC cab Im going to convert ..I converted and used Vintage in my Cheyenne( was a factory AC cab) years ago but their kits are Gens ahead now from when I installed mine ....looking at the condenser install looks clean
Old 10-23-2024, 09:14 AM   #125
raggedjim
raggedjim's Avatar
Nice work on this truck! What did you use to paint the engine? Did you use a clearcoat?
Rg
raggedjim is offline   Reply With Quote
