Old 08-24-2004, 09:18 PM   #1
brranger
install of 502 ram jet
Hello, I am going to install a ram jet 502 into my 1970 C10 2wd that was org. equiped with a 350 in a few months. I am not sure of what brackets will have to be switched over to handle a big block. I know I need motor mounts so far.
brranger is offline   Reply With Quote
Old 08-24-2004, 10:29 PM   #2
hobby67stepside
I wish you good luck, but I think you will need to do quite a little research and talking to people who have done a BB swap. Since the search option here is kaput for now it makes it a little more difficult to get info from guys who have done this.
hobby67stepside is offline   Reply With Quote
Old 08-24-2004, 10:33 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It all depends on which setup of pulleys and brackets you want to run on the front of the engine.
I run the stock type of 72 brackets and pulleys which are short water pump, and I paid hell getting everything I needed. If you settle for the 73 and newer long pump style, it will be much easier.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-24-2004, 11:03 PM   #4
brranger
thanks for the replies I was planning to get a march serpintine setup, Not sure if the motor comes witha long or short pump. tx firefighter did u use big block pulleys and brackets?
