Old 06-03-2023, 06:25 PM   #51
straight6chevyguy
straight6chevyguy's Avatar
Re: 1976 green c10 custom deluxe
Well, getting back on this full steam again.
Actually been working on it but just have not been posting anything.
My main goal right now is to just get the truck running, driving and back on the road.
Body work and all that will be coming along later.
Just getting the truck back on the road is going to be a big accomplishment for me as it has been my dream for many years now.
So starting off...
Brakes are gonna need complete overhaul... Mainly the master cylinder.
I was gonna rebuild it but sorta changed my mind after closer inspection
1965 Chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 Chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 Chevy c20 350 4speed
1998 Chevy c1500 4.3L 5speed
1999 Chevy k1500 Suburban 5.7L auto 4x4
2002 Chevy s10 4.3L auto 4x4
1971 Mercury Monterey wagon 400 auto
Plus other misc. ... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 06-03-2023, 06:32 PM   #52
straight6chevyguy
The head.
And hopefully the last look at the cylinders and pistons.
Old 06-03-2023, 06:40 PM   #53
straight6chevyguy
Head installed and date on one of the trucks original motor mount brackets.
Old 06-03-2023, 06:54 PM   #54
straight6chevyguy
Things starting to get a bit more pretty.
Not the best paint job but good enough for a truck that'll be put to work.
I won't be running this valve cover as someone else tightened a couple bolts down to tight without the proper washers and cracked it.
Old 07-17-2023, 10:58 PM   #55
straight6chevyguy
Got the engine in the truck.
Everything should be smooth from here right?
Old 07-17-2023, 11:18 PM   #56
straight6chevyguy
So After getting the engine in the truck and transmission all mounted up, I went to put the starter in witch for some reason I decided to do after I put the engine in, I found out I was gonna have to switch to a smaller clutch and flywheel in order to run my original bell housing, as my engine block was not drilled for the hole for the offset starter bolt pattern needed for the starter used with the larger 168 tooth flywheel.
For those that want to read more detail about that I will link the thread here:https://67-72chevytrucks.com/vboard/...d.php?t=844927
So Transmission is back in (again)
back to work on the brakes and waiting for the new valve cover to show up.
Also my aftermarket exhaust manifold I got does not have a heat riser installed so there's that I have to figure out.
Old 07-17-2023, 11:36 PM   #57
straight6chevyguy
The Right rear wheel cylinder bleeder screw was stuck and stripped so I pulled the brakes completely apart on that side.
Found my brake shoes were toast so got a set of those as well as a new wheel cylinder as my other one was to pitted to rebuild.
got all that put together yesterday.
Today I installed the new master cylinder and started the bleeding process... went ok until I broke off the bleeder screw on the left rear cylinder
I think that's It for me for today.
Hopefully I can salvage the wheel cylinder if not I'll just get a new one.
But were moving forward folks I'm starting to really really want to get in and drive this thing!
Old 03-08-2024, 02:44 PM   #58
straight6chevyguy
Moving along... Intake and exhaust manifolds are on.
Old 05-13-2024, 02:30 AM   #59
straight6chevyguy
Well I have spent the last couple weeks working hard on the truck getting all the parts and peices put on the engine to get it started.
Finally Today, after a very long time (something like 3 years too long lol) I got the new Engine started! There is still a lot to do to the truck before I can get it back on the road but it feels great to see and hear the engine run! I'm going to be posting a lot more regular updates as I continue to get this thing road worthy so stay tuned!
Old 05-20-2024, 12:56 AM   #60
straight6chevyguy
So yeah, looking a bit more like a truck again... well getting there anyway.
Old 05-20-2024, 01:05 AM   #61
straight6chevyguy
I've had the seat out for a wile its nice to get it back in.
I still need to order a new seat cover the old one was still in one piece but was loosing all its fibers by the millions and they would get all over my clothes every time I got on or off the thing so I decided it would just be best to replace it.
Old 05-20-2024, 01:19 AM   #62
straight6chevyguy
So after getting the engine running I decided to drive the truck down to what was my Grandfathers shop and work on it down there. I had to run the truck off a small gas can since I have removed the fuel tank for cleaning since it was half full off water and old gas. It was my first time driving the truck (with it moving under its own power) so it was pretty exciting.
Also exciting is the fact that it was the first time it had moved under its own power in 18 years!
Old 06-12-2024, 02:05 AM   #63
straight6chevyguy
Last weekend I worked on putting the fuel tank back in the truck.
Got it all hooked up got the engine started and then checked to make sure none of my fuel lines were leaking I looked under the truck and yeah... Disappointing... Yup that's just the way it goes... I have ordered a new tank, it should be here within the week.
Old 06-25-2024, 01:37 AM   #64
straight6chevyguy
I threw on a hood I found at a junkyard but its only slightly better than my old one.
It's rusty and folding in half too however someone has tried to brace it up at some point, they just did not put the brace at the main stress point for some reason...
I'm gonna try to re-brace it and use it for now until I can find another one.
Old 06-25-2024, 01:42 AM   #65
straight6chevyguy
Well thats where it was leaking from lol.
O well new tank is installed now so thats all straightened out.
Old 06-25-2024, 08:28 AM   #66
TKCR
TKCR's Avatar
Wow you made a lot of progress with the engine, good job. And it looks pretty too!
I came aboard for the interior, I love that color also. Those 2 point lap belts are my favorite, I enjoy restoring those.
Old 06-25-2024, 08:46 AM   #67
dagnabbitt
dagnabbitt's Avatar
I like your truck, triple green is something you sure don't see on new vehicles. Love the I6, too.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 06-25-2024, 11:49 AM   #68
Shifty One
Shifty One's Avatar
Lovin' the Kermit-truck!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 06-25-2024, 07:11 PM   #69
LT7A
I'm sorry to hear about your grandparents.
It's great to see the progress you have made. You painted that engine up nice - it looks like it's glowing in there.
Old 07-01-2024, 11:43 PM   #70
straight6chevyguy
Thanks guys,
TKCR, your restored belts look great, I might have to get you to redo mine in the future there pretty cruddy looking lol.
Old 07-01-2024, 11:57 PM   #71
straight6chevyguy
The Heater core was leaking so I pulled the the heater box out.
It looked about as expected mouse nests and all lol.
I have my new heater core just have to get the box cleaned up and get it installed.
With the heater box out I did find my inside plastic door lock piece I lost down the defrost vent years ago, so long ago I forgot it didn't match the drivers side one lol owell it's better than nothing for now I will try to find a correct matching one later on.
Old 07-24-2024, 11:46 PM   #72
straight6chevyguy
Some of the things I've gotten done over the last several weeks...
Got the grill, headlights and all put back on.
over time I must have lost one of the screws for one of the turn signal covers so I found another screw and made a spacer for it.
sadly I dropped one of the turn signal covers on the cement floor in the shop and busted a big chunk out the corner O well life goes on.
I had an extra cover but it was one with the trim on it so I just popped of the trim piece. You can kinda tell that it used to have the trim on it though as the outer edge is less faded. It sorta bugs me but it will have to do for now. I actually had a pair of the covers with the trim but I want to kind of keep the original look of this truck, for the most part anyway.
Old 07-24-2024, 11:58 PM   #73
straight6chevyguy
Also I made a new control lever for the heater controls since one was broken.
made it out of some flat plate aluminum. have not decided if I will bother coming up with a knob piece for the end of the lever. Honestly I dont know if I would do this again it took a long time to make but whatever it does work.
I would suggest to anyone else it would be best to just find another set of controls Lol.
Old 07-25-2024, 07:32 AM   #74
TKCR
TKCR's Avatar
Originally Posted by straight6chevyguy View Post
Thanks guys,
Whenever you’re ready, just send a PM. Or you can contact me on my FB page I have for the belts. Link is at the bottom, on my Signature
Old 08-05-2024, 02:01 AM   #75
straight6chevyguy
Sounds good, don't know how soon cause at the moment I'm excited to get out and drive the truck but I know want to get them re done sometime in the near future for sure.
