Old 03-27-2024, 04:36 PM   #26
OKGMC4
OKGMC4's Avatar
Re: IMPOSTER! ( or hey guys I got a little jimmy!)
While I was at the salvage, I was geekin out about some of the stuff they had. A 65 Mustang, a 50s Mercedes, and this ultra cool International with aftermarket tool box fenders on the step side bed. Those would be cool on a Delmo style build.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 03-28-2024, 01:23 PM   #27
OKGMC4
OKGMC4's Avatar
This is the seat pattern I want to copy, just in a different color scheme. I've had this photo in my pc for years and years, I'm not even sure where it came from anymore.
Old 04-10-2024, 06:07 PM   #28
OKGMC4
OKGMC4's Avatar
Working on building a bed wall / cubby hole behind the seat. Could be a great place for the battery or subwoofers or who knows what. Also got one back inner fender notched around the tire and putting the tub back in. I had bad luck trying to make the 1.5” wide splice to fill the gap when I moved the tub in. I couldn’t get the bead line correct at all with the tools and skills I have. I looked and found Summit had a rear tub by AMD for $60. Sold! I trimmed it to fit all the way to the bed, cut the excess part off the bed wall, and started fitting the tub. The part I cut off I can use to patch the other side, although I almost want to get another cheap tub from Summit. Much much faster.
Old 04-25-2024, 06:51 PM   #29
OKGMC4
OKGMC4's Avatar
Splicing the other tub in.
Old 04-27-2024, 09:11 AM   #30
OKGMC4
OKGMC4's Avatar
Just hammer and dolly work now.
Old 04-27-2024, 09:59 AM   #31
raggedjim
raggedjim's Avatar
Nice! Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 04-28-2024, 07:23 AM   #32
72 tigger
72 tigger's Avatar
You’re good at fabricating!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 04-28-2024, 11:01 AM   #33
jjzepplin
jjzepplin's Avatar
Awesome work! I am in!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-02-2024, 03:05 PM   #34
OKGMC4
OKGMC4's Avatar
Thanks for the kind words!
The dash will be body color, but not the door panels. In an effort to have the door meet the dash and flow together better, I used some 5/16 rod and some sheet metal to rework the lines.
Old 05-04-2024, 12:11 PM   #35
dec010974
dec010974's Avatar
Awesome.
"If I had your hands I would cut my hands off"
dec010974 is offline   Reply With Quote
Old 07-05-2024, 04:40 PM   #36
OKGMC4
OKGMC4's Avatar
Been waiting 16 weeks for the drop member. Looks awesome! Have not even had a chance to get in the garage for 2 months. Online classes and work and grandkids. I’ll get there though. Got tired of fighting the stock crossmember, specifically steering. Could not make a Dakota rack work, and the Porterbuilt stuff should get me back on track.
Old 07-06-2024, 08:53 AM   #37
dec010974
dec010974's Avatar
@OKGMC4
Tha's gonna be a sick ride. I am definitely down for the ride, subscribed.
Old 07-26-2024, 06:51 PM   #38
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Sweet build i fought the front crossmember as well and finally ordered the p.b. set up...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-27-2024, 08:41 PM   #39
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Nice metal work! I'm subbing to watch...
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-28-2024, 02:20 PM   #40
OKGMC4
OKGMC4's Avatar
I try to save cash where I can but this seems like an area that it’s best to not skimp on. I’m still not going crazy with touch screen automated bag systems. Manual switches will be simple and cost effective (cheap).
Old 07-29-2024, 11:22 AM   #41
loudchevy
loudchevy's Avatar
Awesome build! You have some amazing metal working skills.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 08-11-2024, 12:23 PM   #42
OKGMC4
OKGMC4's Avatar
Having some issues with fit. The lower arms would not fit the crossmember. The bushings go in individually but you could only get one side in at a time. Measured the crossmember and got 13 5/16” and outside of the bushings measures 13 7/16”. I think the sleeves were welded slightly off. Rather than calling and arguing with Porter built about this and have to potentially ship parts back and wait even longer, I had my father in law mill 1/16” off each outer bushing face and just installed shims on the inside bushings. Passenger side bolts wouldn’t even go in without drill reaming. These are beautiful parts but for what they cost and how long you have to wait, I think the least they could do is test fit this stuff before shipping it. I also don’t think I should have to print my instructions myself, but also a minor issue.
Old 08-12-2024, 09:23 AM   #43
loudchevy
loudchevy's Avatar
Sucks you had to modify a brand new part, but at least you had the access to a mill to get it done correctly. I would also be upset about having to print the instructions out. That setup does look pretty sweet though.
Scott
2003 Tahoe Stock
Old 09-02-2024, 05:18 PM   #44
OKGMC4
OKGMC4's Avatar
More fit issues with Porter built, maybe. My tires used to be centered in the wheel well. Now it looks like they are about 1.5 inches forward. I’m not sure it’s a deal breaker but would like to know why. Maybe some movement when it’s aligned? I think I need to talk to Porter built about my issues.
Old 09-02-2024, 05:21 PM   #45
OKGMC4
OKGMC4's Avatar
Also didn’t want to pay $300 for motor mounts so I built my own. Bushings with sleeves were $30
Old 09-05-2024, 07:53 PM   #46
OKGMC4
OKGMC4's Avatar
The 5.3 I’m installing is basically stock except a stock ls1 cam I got for $25. I don’t think it will need my spare Doug’s 1 7/8” full length headers so I’m going with cast manifolds. I tried my center dump 99 Vette manifolds and they didn’t fit.
And I got a response from Nate at Porter built. He says the wheel movement forward is completely normal. I feel better about that now.
Old 09-15-2024, 06:17 PM   #47
OKGMC4
OKGMC4's Avatar
I didn’t want to spend $350 for a sway bar so I went to the bone yard with a tape measure. I ended up with a 1999 S10 1 1/8” bar for 20 bucks. With the new links and bushings I’m in for about $70. It looks close to the tie rods but I turned the wheels lock to lock and aired it up and down and nothing touches. I’d call it a win.
