Old 07-23-2024, 10:32 PM   #1
chris989
134a what size orifice
Hello all,
1989 v2500 suburban
While chasing a leak,, I installed a new fixed white orifice and now the low pressure is a little high and it will not pull temps lower the ~60 at the vent.
I pulled out a VOV valve that was a little dirty and did not take note of the color.
I am thinking of pumping back down and installing a .067.
What did others use? How many Ounces of 134 did you use?
Thanks,
Chris
chris989 is offline   Reply With Quote
Old 07-25-2024, 08:11 PM   #2
v30crewcab
v30crewcab's Avatar
Re: 134a what size orifice
the .067 should work good. I think thats what is in my truck.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 07-25-2024, 10:05 PM   #3
chris989
I reinstalled the VOV
https://www.napaonline.com/en/p/TEM207325
i have 42-48 degrees at the vent
Old 07-26-2024, 12:35 PM   #4
Hart_Rod
Hart_Rod's Avatar
Just curious why did you chose that one?
Hart_Rod is offline   Reply With Quote
Old 07-27-2024, 07:55 PM   #5
hatzie
Moderator
hatzie's Avatar
I've used the .067" Ford Blue orifice tubes and VOV for R12 to R134a conversions. The C4 Vette guys prefer the Ford Blue tubes rather than the VOV.
Variable orifice valves have been hit or miss for me as they aged. I used to recommend them. I've come to the conclusion that moving parts are not a great thing for long term reliability.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-27-2024, 08:46 PM   #6
v30crewcab
v30crewcab's Avatar
whats the part # for the ford blue tube?
71 longbed 5.3 4l80
Old 07-27-2024, 09:21 PM   #7
hatzie
Moderator
hatzie's Avatar
Four Seasons 38621
Old 07-28-2024, 10:42 AM   #8
chris989
It is what I used when i swapped from 12 to 134. I only went white fixed because I had it on the shelf and that is what is called for.
I am using a Sanden SD7,, With the fixed i could not get decent temps.. My motor runs around 2,000 or less in town.
Chris
Old 07-28-2024, 05:19 PM   #9
hatzie
Moderator
hatzie's Avatar
Chris
The white GM orifice is 0.072
That's just fine for hydrocarbon R290 and R12.
You need a slightly smaller orifice for R134a and HFC152.
As I said the Ford blue is 0.067 and it seems to do the job.
Old 07-29-2024, 09:07 AM   #10
Hart_Rod
Hart_Rod's Avatar
Chris
Gotcha. I talked to a local Hotrodder than runs an AC shop. He recommended the white one, so that's what I used when I did the LT swap in my 84 (Sanden compressor/134A). So far, it cools great with no issues. Hatzie - what symptoms should I look out for that might suggest that I switch to the blue one?
Old 07-29-2024, 01:22 PM   #11
hatzie
Moderator
hatzie's Avatar
Higher vent temps when you're in traffic with the engine idling or near idling.
If your set up is working I'd stick with it.
Old 07-30-2024, 10:03 AM   #12
Hart_Rod
Hart_Rod's Avatar
Thanks. Will report back if I see any changes.
Rob
