Old 07-28-2024, 01:56 PM   #1
kglowacky
K&N Air filters
Second time in 3 years my K&N air filter fell apart. Thet rubber ring that fastens to the round metal tube rotted/torn away. Any one have a better filter I can buy.
Part number HPR9891. Looks like the weight of the filter tore the rubber. Maybe I need to build a strap to support the filter. Thoughts.
kglowacky is offline   Reply With Quote
Old 07-28-2024, 03:37 PM   #2
Joyridin
Re: K&N Air filters
The number you gave is a Spectre filter, not a K&N. Are you sure K&N makes the filter for Spectre? I have had dozens of K&N filters over the years and never had one fall apart.
Joyridin is offline   Reply With Quote
Old 07-28-2024, 04:58 PM   #3
LS short box
Re: K&N Air filters
The K&N I have on 98 Wrangler LS6/4L60E swap is 15 years old with zero issues.
I use K&N on all my LS swaps.
Old 07-28-2024, 07:33 PM   #4
kglowacky
Re: K&N Air filters
from what I read K&N or vis versa owns Spectre. The problem seems to be the weight of the filter bouncing up and down when you drive it rips the rubber after a couple years. Looking for a different filter maybe not as heavy or even shorter that will bolt right up.
6 inch dia connection to air tube
The rubber is literally falling apart as I handle it. Ordered a new real K&N this morning. Will update.
Old 07-29-2024, 05:03 PM   #5
LS short box
Re: K&N Air filters
So one thing I always do is add a bracket that supports the air tube near the air filter.
Bracket is bolted to the head and to the bottom of the air tube. Not to the radiator support.
Old 07-29-2024, 06:22 PM   #6
kglowacky
Re: K&N Air filters
thinking same thing. I will jb weld the bracket to the outside of end of filter (medal Part and bolt to box. My luck I would bolt it and the bolt would come loose and it would get sucked into the intake. LOL I am the Optimus.
Old 07-29-2024, 09:45 PM   #7
LS short box
Re: K&N Air filters
I JB weld the bolt from the inside of the air tube. Then just a nut and lock washer on the outside. The JB weld helps seal the tube around the bolt.
