Antenna
Has anyone successfully managed to take an antenna cable apart. Been looking at it for a couple days and can’t find a way to replace cable
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; Yesterday at 07:18 AM. |
![]() Join Date: Feb 2002
Re: Antenna
[quote=jaros44sr;9330440]Has anyone successfully managed to take an antenna cable apart. Been looking at it for a couple days and can’t find a way to replace cable
![]() You need to find a local Ham shop. CB would have done, but that's archaic now. Get some fresh coax, and have them put a fresh plug on the end.
Re: Antenna
Thanks for your time I'll do a search in my area
Re: Antenna
Never saw the insides dremel tool time
![]() Join Date: Jul 2003
If repairing the original doesn't pan out, this is all available new for around $60.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Re: Antenna
I took mine apart and replaced the cable. You need to pull that strap clamp off and the rubber piece will come off. Then you can see what you need to solder.
