#251 |
Re: Random pictures you took of your K
Agreed, very nice truck, great pic but let's not ignore that sharp looking pup in the pic too.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
#252 |
Took this one of Papa's truck the other evening.
#253 |
My 91 Blazer
John '91 Blazer, full top, bbc, 4spd, Doubler, 1 tons, 40's |
#254 |
![]() ![]() Join Date: Mar 2016
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE ![]() |
#255 |
All about them K’s
![]() Join Date: Jun 2014
Front Dana 60 and lift kit time… (only half done on the 5” lift kit)
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#256 |
Just had new tires installed.
-400/400 1979 K25 350/SM465/205/44HD/14FF 1985 K20 400/400/208/10/14 1987 V10 TBI350/700R4/208/10/10 '85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968 |
#257 |
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, No Snivelers "No Lowballers, I know what I got"
#258 |
All about them K’s
An updated pic of my K2500. I swapped the 315/75/16’s for 35x12.5x20’s over the weekend as well as changing the gear oil, engine oil, valve cover gaskets and recharged the ac. It goes back to daily driver duty next Monday.
#259 |
All about them K’s
And… an updated pic of my K20… rockin ‘em Mickey Thompson classic II’s and 315/75/16’s
#260 |
Next to a co-workers 4x4 swapped f***.
#261 |
All about them K’s
Well I can tell you who’s truck is truly bad ass… it’s not the Furd… I really love your truck! Simple but classy at the same time.
#262 | |
My co-worker does a nice job with his swaps. Just not sure why he starts with the wrong trucks... How’s the k2500 been treating you on the daily duty? Did something happen to your work truck?
#263 |
![]() Join Date: Feb 2009
One I just sold…
#264 | |
All about them K’s
Lol some people can’t help but pick subpar ford projects for starting points on projects… I’ve found in my life that the best projects are the ones that are more than 10 years in the making. I’ve got a few long haulers my self. It’s always fun to look back and see where they’ve come from and where they are going. Man that old K2500 is such an awesome truck. I really can’t say enough about the GMT 400’s they really got the durability and longevity of them right. That truck has about 210,000 on it. and before mid may had been less than 1,000 miles in 10 years. From June of 2021 to September of 2023 I’d didn’t run a single time. I put a battery in it and 5 gallons of fresh fuel in the tank and fired right up. I parked it in 2021 because the input shaft seal in the transfer case was leaking and allowing the transmission to fill the transfer case. I replaced that seal and it mostly sat again for 4-5 months only being started up enough to keep the battery charged. Fast forward to May and I got a job opportunity 3 hours from my then home that I couldn’t turn down. So I surrendered the company truck and started making the weekly commute to Albuquerque and coming home in the weekends. I changed the transmission fluid last fall, the engine oil, valve cover gaskets, front and rear diff oil in May. Put a new set of wheels and tires on it and Drove it to Albuquerque. Coming home it killed a cv shaft boot like it did every other year when I was really driving it. I also had a rear hub seal leak a while back that killed the brake shoes. Fixed the leak but didn’t have time to put shoes on it then. The upper ball joints usually only last 20-30,000 because of the lift too. Last weekend I swapped the brake shoes, cv axle, and upper ball joints out. For sitting as long as it has I’ve got maybe 500 in it not including the wheels and tires, (the tires were from 2010) and it’s running really really good, I’ve got cold 35* AC and all. It’s still got the original drivetrain in it and none of it has ever been rebuilt. Once I get into a new house I’m gonna build a shop and paint it but other wise it’s been a really really good truck. I’ve had it 13 years now and I’d still not hesitate to drive it coast to coast.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 07-04-2024 at 05:26 PM. |
#265 |
From the monthly cruise night in Peru Indiana. About 200 cars and trucks showed up for the July meet.
Click below to see my build thread...lot's of stuff there http://67-72chevytrucks.com/vboard/s...d.php?t=494493 |
#266 |
![]() Join Date: Jun 2019
#267 |
At the local firehouse alongside my friends 51 sedan delivery on a rainy CA spring day
#268 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#269 |
LOL $$$
#270 |
![]() ![]() Join Date: Feb 2004
All 3, 2 are 4wd --- New wheels and new valve covers on 67. Newer wheels (88-98 stock rally) on 59.
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt Last edited by dennislbrooks; 08-10-2024 at 06:00 PM. Reason: pic |
#271 |
All three are very nice, partial to that 59!
#272 |
Here is a better pic of 59's wheels now 89-98 stock rally. Truck originally had 6.50x16LT on it - when I got it. Now 215/85x16. The spare is actually a 6.50x16LT Tubeless Nylon on the oe rim with 59 hubcap.
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt Last edited by dennislbrooks; 08-13-2024 at 08:18 AM. Reason: words |
#273 |
Thanks. She loves truck rides.
#274 |
All about them K’s
Here’s a recent pic of a few of mine,
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 12-02-2024 at 02:58 PM. |
#275 |
I had to lookup where Land Of Entrapment is --- New Mexico. 8-)
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
