69 C10 with a 6l90 transmission HELP
Hoping to get some help. I have read that when putting a 6l90 that I would need to cut the floor and use the high hump. So I did that and put the cab in the frame and as you can see by the pic the end shaft and the 3 bolt flange are inside the cab. I have Holley motor mounts and tinworks frame stiffener with trans mount. I don’t know the angle of the engine and transmission. I know it should be 3 deg I just don’t know if that will give me the clearance I need. Let me know what I need to do. TIA
Re: 69 C10 with a 6l90 transmission HELP
Not the same as your application, but mine took 3 different motor mount combinations before getting engine placement correct.
.. More information needed for others to help solve your dilemma. Photos also get you better responses.....good luck.
Pic
considered ditching the huge bolt flange and using a slip yoke?
