07-28-2024, 10:44 AM | #1 |
This might need to be a sticky on disc brake conversions
**I say this should be a sticky as I think this would help a lot of folks pulling their hair out trying to fix this issue**
So i just got done doing a 4 wheel power disc conversion on my 64 c10 with a wilwood adj proportioning valve for the rear. -bench bleed master cyl -bleed brakes using the 2 person method in this order: lft rear (has longest amount of brake line), rt rear, rt front, lft front -Can't get a good pedal until it's about 3 in off the floor. Of course,I layed in bed and can't sleep try to figure out what i did wrong (as most of us do when we can't the solution to our problem and have to quit for the day....lol) I found this on youtube this morning. The guy said most disc brake kits don't say a thing about doing this, I can tell you the auto city classic stuff doesn't. YOU HAVE TO DRILL A NEW BRAKE PUSH ROD MOUNTING HOLE 1 IN LOWER FROM THE ORIGINAL MOUNTING HOLE. here's the link what he shows the difference in pedal travel: https://www.youtube.com/watch?v=iGVNJ87szt0 Last edited by 64stpside; 07-31-2024 at 09:19 AM. |
07-30-2024, 12:26 AM | #2 |
67-72 parts collector,…
Re: This might need to be a sticky on disc brake conversions
But are you taking about manual brake master cylinder or one with a booster behind it?
07-31-2024, 09:19 AM | #3 |
08-01-2024, 04:44 PM | #4 |
Manual drum to manual or power disc require changing the pedal pivot point on OE linkages. It's also required if changing a vacuum/pwr brake set-up to/from Hydraboost.
All utilize a slightly different ratio. Master cylinder 'bore' sizes are also different depending on the combination of parts used.
08-08-2024, 10:29 PM | #5 |
Manual pedal ratio is generally around 6:1, power brakes are generally around 4:1. My stock '66 C10 has a 6.25 ratio. The higher the number, the more leverage the pedal has on the master cylinder.
When you convert to power brakes you do two things to take away braking power- reduce the pedal ratio by about 35%, and you generally go from a 1" bore MC to a 1.125" bore MC, reducing output PSI by 20%. The booster is supposed to more than make up for that, right? With a stock 6.25 pedal ratio and 100 pounds of input force on the pedal you get 625 pounds of force into the MC, which is hydraulically multiplied via the MC's piston surface area of .785 square inch. 625 pounds in turns into 790 PSI at the caliper if you have the typical 1" bore MC. With a power brake conversion, 100 pounds of force on the pedal gets multiplied by 4 via the pedal ratio for 400 pounds into the pushrod/booster. CPP says a 7" dual diaphragm booster adds 493 pounds of force for 893 pounds of force into the MC. The typical 1.125" MC will turn 893 pounds of input force into the same 893- the bore size has 1 square inch of area so it doesn't multiply the input force any so you have 893 psi at the caliper. This is about 13% more psi than the typical manual setup ** BUT ** this is assuming 23" of manifold vacuum. How many trucks actually make 23" of vacuum? That 13 % advantage quickly fades in the real world. What happens if we stay with manual brakes but drop down to a smaller master cylinder bore to multiply input force more? With a 15/16" bore you get 905 psi at the caliper, and 7/8" would have 1041 psi. Brake pedal input to output is totally linear and not variable with manifold vacuum, and they work 100% the same with the engine on or off. It's cheaper and easier because pedal modifications aren't needed. But, everyone says you need power brakes "because they stop better" and brake companies need you to keep believing that so you keep buying their aftermarket "upgrade" parts... The one benefit to power brakes is that they can have less pedal travel than manual brakes, because of the shorter pedal throw due to the lower ratio, and because the bigger MC bore displaces more fluid for the same amount of travel. Is this an issue in the real world? Its not on my '66 with the stock 6.25 pedal ratio, 1" bore MC, the usual squarebody D52 12" discs in front, and stock rear drums. The pedal drops a normal amount and pedal effort is pretty normal too. If you have air in the lines then you'll have more pedal travel since air is compressible, but you shouldn't have air in the lines if you bleed them correctly. If you have bigger/multi-piston calipers then you'd need to design the whole system around the amount of volume/pressure they need. But for the typical D52 disc setup, a manual 1" bore MC works great and makes plenty of hydraulic pressure without the pedal travel being any more than normal.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
