Old 06-22-2024, 05:02 PM   #301
65Custom
Re: 65Custom Build Thread
Well its welded in and has changed slightly from the first go round, I think it will look good once it is finished out and motor is in etc won't really notice it that much, but serves the purpose of getting the motor pushed back and fitting in better.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 07-02-2024, 10:22 PM   #302
65Custom
Piece of advice
What ever you do not ever add up all your invoices to see what your project has cost you.
My Build Thread
I must be
Old 07-13-2024, 09:28 PM   #303
65Custom
Getting a little hood repair the front inner structure was rusted but the exterior hardly showed any signs of rust. Cut down the steering column 3" to be able to fit the steering linkage for the rack. Mounted the rear sway bar. Filling all the little holes which showed up after the sand blasting.
My Build Thread
I must be
Old 07-13-2024, 09:30 PM   #304
65Custom
mounted rear sway bar
My Build Thread
I must be
Old 07-20-2024, 04:21 PM   #305
65Custom
The hood front inner support is repaired and installed back into place
Front sway bar is in place
I like this Tailgate mod
My Build Thread
I must be
Old 07-21-2024, 03:27 PM   #306
65Custom
coolc10 is now making an air box to go with the center ac vent he sells,
I purchased one and I am really happy with how it seals to the front ac vent cover this will really make a difference in how well this vent works.
My Build Thread
I must be
Old 07-22-2024, 02:13 AM   #307
Braunschweiger
Nice Part, looks good
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is online now   Reply With Quote
Old 08-05-2024, 08:49 PM   #308
65Custom
Update, temp wheels on ready to be put back on the ground soon 15 years since it has had wheels on it. inner fenders needed to be modified to fit over the new coil-overs and also need cover the old steering column hole in the inner fender. Front wheels are more centered in the wheel well now, that turned out well, once the bed is back on we will get a look at how the rear wheels align in the opening, since the front worked out so well the rear should look just as good.
My Build Thread
I must be
Old 08-05-2024, 08:53 PM   #309
65Custom
The tailgate is now finished
My Build Thread
I must be
Old 08-16-2024, 09:45 PM   #310
65Custom
Getting down to the last few bits of things needed before going to paint and body work.
Inner fender changed, removed the steering column slot since it is not needed.
My Build Thread
I must be
Old 08-19-2024, 10:27 AM   #311
joesscamaro
Nice work! Looking really good. Are you sending it to a body shop or will you be taking that on yourself?
joesscamaro is offline   Reply With Quote
Old 08-19-2024, 08:57 PM   #312
65Custom
She's going to a paint and body guy, I would like to leave that up the professional.
My Build Thread
I must be
