08-25-2024, 12:28 PM | #1 |
'67 12 bolt gear ratio
I have a '67 Chevy SWB frame with a 12 bolt....trying to figure the ratio, best I can tell it comes out to be a 340. I don't know if it's really a 336,342 or 355. Guess I'll have to pull the cover off. I think it was an I6.
08-25-2024, 01:23 PM | #2 |
Re: '67 12 bolt gear ratio
If your count is correct it is probably a 3.42. I have not heard of a 3.55 or 3.36 used on GM trucks.
08-25-2024, 02:36 PM | #3 |
My truck ['68 C/10 Stepside] came with a Factory 292 L6 and a 3.73 rear end ratio.
08-25-2024, 07:13 PM | #4 |
08-25-2024, 08:36 PM | #5 |
Factory i6, should be 3.73 which is an awesome ratio
1969 C10 Shortbed |
08-26-2024, 08:44 PM | #6 |
3.40 was a factory gear set in the mid 70’s for a couple of years. They are not super common, but you come across them. 34 teeth on the ring gear and 10 on the pinion. Not 3.42 ratio like you would find in a 10 bolt. As mentioned above, 3.73 would have been the standard gear in your truck. Any option would be listed on the SPID.
08-27-2024, 07:14 AM | #7 |
I know in 50 plus yrs It could’ve been changed, but you could always check the code on the axle tube. Should be on the passenger side between the trailing arm mount and carrier housing. It usually anywhere from 12 to 3 o’clock on the tube.
08-28-2024, 12:00 AM | #8 |
The Older Generation
If you find the code on the axle tube or housing here are the conversion charts I posted a few years ago. http://67-72chevytrucks.com/vboard/s...d.php?t=578793 Check posts #8 & #19 for a couple of the code stamp locations.. .
08-28-2024, 04:04 PM | #9 |
If you don't want to pull the diff cover you can use these two calculators.
Get you tire size https://tiresize.com/calculator/ To find you gear ratio take the truck out and use your GPS to get an accurate MPH and a tach to get your RPM in top gear at like 70mph. Then put all that info onto https://www.summitracing.com/popup/c...iAAEgIFzvD_BwE
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
