08-25-2024, 04:16 PM | #26 |
Re: Heater blower ?/problem
Pic of washer
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
08-25-2024, 04:32 PM | #27 |
08-25-2024, 04:50 PM | #28 |
Tks. I figured out that the square washer went on first. I had the cage on. Upside down !!! So u were right. Flipped it over and checked for motor operation. It spins while hooked directly to battery. I'll pick it up in the morning. Tks again
08-26-2024, 11:59 AM | #29 |
Reinstalled heater motor. Worked with jumper wire to battery +. Rehooked batt to truck. System now works as advertised with one exception. I have an open circuit from fuze box to connection to on_off and fan speed switch. Brown wire I believe. So I hooked up temp wire from heater fuze to switch. Works fine. So what open fuze spot would be good to connect wire permanately ? I don't want to leave it rigged with just the wire behind fuze.
08-26-2024, 12:19 PM | #30 |
Do you have a good 10A fuse installed in the slot labeled "AIR COND."?
08-26-2024, 12:31 PM | #31 |
I do now. One in there was blown
08-26-2024, 12:35 PM | #32 |
Do you have power on the stock brown wire now?
08-26-2024, 12:52 PM | #33 |
Yes sir
08-26-2024, 01:14 PM | #34 |
So everything is working now?
08-26-2024, 01:29 PM | #35 |
Yes sir. Thank you very much. Tks for sticking in there with me till the end !!!! If I can ever return the favor I certainly will !!!
08-26-2024, 01:30 PM | #36 |
All this started with me just checking things out on truck to prepare it for sale. Now I can proceed. Tks again.
08-26-2024, 01:32 PM | #37 |
I'm glad you were able to get it working.
08-26-2024, 02:32 PM | #38 |
20' Daredevil (Ret)
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
