08-24-2024, 07:37 PM | #1 |
Longhorn cut down to short box
Has anyone ever done this yet ?
08-24-2024, 08:51 PM | #2 |
All about them K’s
Re: Longhorn cut down to short box
I’m sure someone has but can’t for the life of me imagine why someone would. That longhorn is a real truck, built to work its butt off day in and day out.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
08-24-2024, 09:15 PM | #3 |
I've never done it, nor seen it done.. I wouldn't advise doing it for two reasons -- (1) bad idea, and (2) bad idea... OK 3 reasons.. (3) As Taskforce said -- It's a real truck, built to work, not parked in a space at some car show...
08-24-2024, 09:23 PM | #4 |
Who Changed This?
A Longhorn has a 1T frame. It rides hard already, unless loaded. Shorter would be worse, and what would a C-notch look like? I have so many questions about why.
08-25-2024, 02:37 AM | #5 |
You most likely wont find the answers you are looking for here. This place is great, but tends to lean more to the preservation or stock side of things.
If you have InstaGram reach out to @classic_chev, he does a lot of boxside shortening and may be able to help you. He’s also a member here, but for the life of me i can’t remember his handle.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
08-25-2024, 03:04 AM | #6 |
all i could say , if you want a short bed
sell the truck and buy a short bed at where you start from not to many longhorn(s) out there . . .
dont want to hear excuses, i want to hear solution(s) |
08-25-2024, 03:22 AM | #7 |
Ouch.
08-26-2024, 02:39 AM | #8 |
Does the OP intend to swap the suspension for that of a half ton? If not, anyone who sees it will know it isn't right.
I'd also agree that longhorns are somewhat rare if not terribly desirable. Why hack one if you don't need to? |
08-26-2024, 03:57 AM | #9 |
Location: Herculaneum MO (20 minutes south of St. Louis
The why is in his user name. He is obviously looking for a way to throw away or burn some of that excess cash. That's the only possible reason.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
08-26-2024, 12:05 PM | #10 |
At the body shop.
Excuse me, some of your purist maybe showing.
My favorite is the C20 made into a K5-
" That didnt make it any newer " " Dont antique the equipment " |
08-26-2024, 04:05 PM | #11 | |
While I wouldn't cut a 'Longhorn' down to a shorty for the exact reason it is a Longhorn (the rare, longer than standard LWB HD frame & extended long bed), there are plenty of guys building HD 4x4 Blazers on SWB length frames so it's entirely possible someone w/the right skillset, vision, & bank account could pull off a bad-arse build of one. In a nutshell..... Do it if 'ya want. Don't like the idea? Provide respectful info advising why it shouldn't be done. Beyond that, if you don't have anything nice or constructive to say, don't say anything.
08-26-2024, 06:08 PM | #12 |
I agree that the guy just asked a question, no need to ridicule.
Maybe the Longhorn is a wreck and whatever he has planned will save it from being crushed: who knows. I wouldn't do it, but I would admire the craftmanship if it were done well. As hypotheticals go, it is definitely the first time someone has asked the question, on a forum with about 10 million posts.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
08-26-2024, 08:43 PM | #13 |
I personally would not cut down a longhorn if it was complete and could be made into a usable truck. If the body panels (bed) was shot I could see converting to a short bed HEAVY DUTY 4x4 or a lowered SB with a 2 stroke Detroit Diesel (if I had the skill/ money to do so).My suggestion is if you own it and converting the truck to a short bed gets you the truck you want go for it. If you decide to go for it hopefully you have the Time/Money and patience to see it through ( I never seem to have these at the same time). How many
conversions/restorations get started and never completed? Too many. |
08-26-2024, 09:14 PM | #14 |
If you can keep the bed or trade it to someone who has looked for one for quite a while like I did. I was wanting a longhorn bed to make a dually bed out of. A regular long bed might could be bought cheap enough to cut down and still have what you want, and preserve the rare long horn. But if another bed isn't a viable option cut away it is your and I'll support your decision. Jim
08-26-2024, 11:21 PM | #15 |
*Actually Jimmys are not designated K/5s. K/750 would be the equivalent to the Blazer's K/5, but GMC doesn't play games. A 4X4 Jimmy is a K/1500 just like a pickup.
08-27-2024, 11:24 AM | #16 |
At the body shop.
Too bad it wasn't a longhorn into a Jimmy...
08-27-2024, 11:45 AM | #17 |
This falls into the same category as I see crew cab duallies being slammed to the ground with the frames cut up for a C notch. My take is an abomination and a desecration of a good truck. But it's your money and your truck. I cringe as I've still got 1 longhorn left I haven't sold---yet
08-27-2024, 01:15 PM | #18 |
All about them K’s
Personally the only thing I’d ever change on a longhorn is add a front dana 60 and an Np205 to it. I know I’m different than most here. Truthfully I could care less about a slammed 2wd short bed that blends in with every other one out there. I’m not a purist by any means. I like certain modifications. I’m just not really a lowered chopped 2wd guy. Hence why I said I would leave it that 1 ton work truck it was meant to be. I’ve got a couple Camaros for sitting low and going fast, I like my trucks to be functional for truck stuff when I need them to be. No offense meant just my personal out look on things.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 08-27-2024 at 01:22 PM. |
08-27-2024, 01:59 PM | #19 | |
08-27-2024, 03:36 PM | #20 | |
08-27-2024, 07:29 PM | #21 |
There you go...
With duallies.
08-27-2024, 08:55 PM | #22 |
Who Changed This?
^ Gad, what an atrocity that would be!
08-27-2024, 11:06 PM | #23 |
At the body shop.
I kinda hope they cut up a long horn.
But probably a c50 Keep in mind I have a stretched shortbed C10 so my opinion is really skewed
