09-11-2024, 02:28 PM | #1 |
Active Member
ARB AirLockers F/R 71 K5
Hello,
I'm considering ARB Air lockers for my front diff, a Dana 44, and my rear diff, a corporate 12 bolt. I believe they are both bone stock internally. Is there a simple way to determine what gearing they have to pick the correct ARB set up to order? Mike |
09-12-2024, 12:24 AM | #2 |
All about them K’s
Re: ARB AirLockers F/R 71 K5
If the 44 still has the small ratio tag bolted to the front cover it will tell you. If not you can pull either cover and look at the ring gear. It should have the pinion and ring gear teeth numbers etched or stamped on it. For example 3:73 should read 41-11, I’ve seen them stamped the other way too; 11-41 either way if you do the math from there you’ll know what you’ve got.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
09-13-2024, 09:33 PM | #3 | |
Active Member
Perfect, thanks for the straightforward answer. |
11-21-2024, 01:42 PM | #4 |
Why pull a cover? Then you have a big mess, plus scraping gaskets, sealant. Why not count the number of turns from the drive shaft to the wheel? A jack, a piece of tape and 15 minutes and you are done.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
